I have changed plugs & wires, fuel filter, air filter, oil & oil filter and both O2 sensors. Car still has a miss to it. Making a "putt putt " sound from the exhaust pipe.
Otherwise, car runs fine. Only misses at idle or when car is in park. Can anyonesuggest anythig else to check?
** I also replaced the ignition coil. **
Saturday, December 22nd, 2007 AT 1:28 PM
TAURUSWHEEL
MECHANIC
Have you hooked a vacuum gauge to see if there's a "burp" in the vacuum reading along with the putt-putting? Maybe just an exhaust leak, little rot hole?
