Drivers side door replacement
VTMAN802
  • 2002 FORD TAURUS
6 cyl Front Wheel Drive Automatic 157000 miles
Need to replace drivers side door, due to a kami-kazi deer (it did live).I have replacement door ready to go. Each door has auto. Door locks, power windows, and mirrors. Would appreciate directions, or the procedure to complete this. It looks fairly easy, still I like to know i'm doing it correctly.
Friday, May 7th, 2010 AT 4:43 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
The first thing you must do is remove the door panel this guide will help you with that.
https://www.2carpros.com/articles/door-panel-removal
To remove the power equipment, you will need to either pop out the apparatus with the various switches and remove the interior of the door. Once the interior door covering is removed, you will see several ports into the door. If the new door has the electronics already installed, all you will need to do is to unplug these devices. If you will have to do a conversion, unplug them for now and leave them in place. Feed the electrical wiring through the port on the edge of the door by the hinges.
Use a wrench and unbolt the door from the car body. This job is much easier if you have someone who can hold up on the door while you loosen the hinges. Most hinges have three or four bolts, and most doors have two hinges. Keep track of these bolts. They should all be alike, but if there are differences, mark where each bolt should be returned when putting the new door in place. Once the bolts are all out, remove the door and install new. Be sure to align the door properly once bolted back on.
Here are some diagrams (below) that will help you get the job done.
Cheers, Ken
Thursday, August 3rd, 2017 AT 5:10 PM
MJHELLYAR
  • 2000 FORD TAURUS
  • 116,000 MILES
My right side rear door was badly damaged by a fallen tree that went through the window. I bought a right side rear door for my 2000 Ford Taurus SE from a salvage yard and want to replace it with the damaged door. The replacement door has the hinges as well as the arm that goes inside the door. Should I remove the hinges on the replacement door and attach it to the hinges already on the car as this seems like the easiest means of insalling the door since access to the bolts is easiest this way.
Thursday, August 3rd, 2017 AT 5:11 PM (Merged)
BILLYMAC
  • 2,204 POSTS
Yes this would be the easiest way of replacing the door
ILUVNINZ
  • 1998 FORD TAURUS
1998 Ford Taurus 6 cyl Two Wheel Drive Automatic
how to remove taurus drivers side door manual or diagram
BLACKOP555
  • 10,371 POSTS
You trying to remove the door and all off the car or are you just wanting to get off teh panel?
REDD LEWIS
  • 1999 FORD TAURUS
  • 6 CYL
  • 156,000 MILES
Computer problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic 156000 miles
WHAT DO I NEED TO DO TO CHANGE THE CODE?
BILLYMAC
  • 2,204 POSTS
Call your local ford dealer they will give you the procedure
Thursday, August 3rd, 2017 AT 5:12 PM (Merged)
  • 52,797 POSTS
Please explain, I have no idea what the failure is here
