1994 Ford Taurus
1994 FORD TAURUS
LOONY-TOON
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
my 94 taurus wont start.the battery is fine the starter is fine the fule pump is fine n the spark plugs r fine n so r the wiers for them.when i try to start it it trys to start but just wont.turns over n all just wont start. i cant fine anything rong with it besides that it just wont start. could it be the crank shaft sensor or what??? i need to fix this problem so what do i do?
May 7, 2010 at 5:59 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
https://www.2carpros.com/dia/how_to_check_compression.htm
https://www.2carpros.com/dia/index.htm
If you smell gas, check your oil level too, gas can be washing the cylider walls and filling up the crankcase...not good, this can and will damage the engine!
May 7, 2010 at 6:07 PM
