Monday, December 28th, 2009 AT 1:30 AM
My 93 Taurus has an intermittent heating problem. When I start the car after sitting overnight or for at least 4-5 hours, the heat will be run very hot as the car heats up, for about an hour, after that it turns cold. Within the last 18 months I have replaced (not for this problem) the water pump, radiator and fan, and a couple of thermostats. The hoses going in and out of the heater core are hot and there are no apparent vacuum line leaks. The temperature setting control on the dash is digital set by degrees. Please help as it is very cold out here.
