Headlight lens replacement?
CRAIGR1953
  • 1999 FORD RANGER
  • 1.4L
  • 4 CYL
  • MANUAL
  • 176,000 MILES
How to remove clips to replace the headlight bulbs and lens assembly?
Friday, February 28th, 2014 AT 11:18 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,082 POSTS
The are not clips you must replace the entire lens. Here is a guide to help you see what you are info when doing the job. This video shows the job being done on a similar car but the process is the same.
https://youtu.be/IZ2vCCPxLqU
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/headlight-lens-replacement
Here is what it is like on your car (below) Please let us know what happens.
Wednesday, September 30th, 2020 AT 5:02 PM
WIBBELS
  • 1999 FORD RANGER
  • 4 CYL
  • 90,000 MILES
How do I replace the headlight assembly on this vehicle
Wednesday, June 2nd, 2021 AT 2:00 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
First, remove the metal clips from the plastic nuts where the headlight adjusters are. Second, unscrew the nuts (3 each headlamp)from the adjuster screw. Third, slowly wiggle the headlight assembly forward. Fourth, disconnect the wire assembly from the headlight.
You should take your truck to an inspection station (or garage) to have the final adjustment (aiming) made to the lights.
STEVESTACY
  • 1998 FORD RANGER
  • 6 CYL
  • MANUAL
  • 175,000 MILES
How do I replace damaged headlight and turn signal for 98 ford ranger
  • 108,328 POSTS
The light assembly is mounted under the hood. Open the hood to access the mounting bolts. Remove the light sockets from the assembly, remove mounting bolts, and remove the old and replace it with a new one.
SWITTY123
  • 5 POSTS
  • 1994 FORD RANGER
  • 150,000 MILES
I was hoping someone could give me instructions on how to remove and clean the lamp lens. Is there any headlight that would give me a better cone shape on the road rather than than stock one I have now?
Thanks
DAN_K
  • 213 POSTS
The choices are almost endless in the aftermarket for replacement headlamp bulbs. If cost is not an issue, HID (High Intensity Discharge) systems may also be available but these systems can be very pricey. I have such a system in my vehicle. From the outside, they have a bluish tint, but from the driver's perspective, it's a very bright white light. These systems require a transformer(s) to provide voltage to the HID bulbs. The best way may be trial and error.
SWITTY123
  • 5 POSTS
Ok thank you very much this is helpful.
  • 108,328 POSTS
There are many that will help. Ask at a parts store what they have available.
KAREN ISAAC
  • FORD RANGER
Need instructions on how to change the entire headlight lens. The lights have a weird little clamp on it. I really don't want to break it, but would like to know how to get that little clamp off. Thanks so much!
RUDPRO
  • 224 POSTS
Here's an exploded view that should help. View "A" is looking at it from behind. It looks like there are 3 clips that pull straight up.
https://www.2carpros.com/forum/automotive_pictures/74660_Ranger_Headlight_1.jpg
