Battery saver relay location
ANONYMOUS
  • 2003 FORD RANGER
  • 50,000 MILES
Where is the Battery Saver Relay located on this truck?
Saturday, December 8th, 2012 AT 7:31 PM
  • 52,797 POSTS
The battery saver relay is under the hood here is a guide to help you test it and the location of the relay in the diagrams below.
Here are the fuse panel and relay locations for your car.
Cheers, Roy
Saturday, December 8th, 2012 AT 7:32 PM
POSTALBOB
  • 1997 FORD RANGER
  • 6 CYL
  • 180,000 MILES
My starter won't engage always when I turn the ignition. I changed the solenoid. Each time I undo the battery cables from the battery and the attachments to the solenoid, it will turn over when I reattach everything. After I changed the solenoid, it turned over about ten times in a row and thought it was fixed. Now it is just clicking again when I turn the ignition. Do you think it might be a worn battery cable or should I take off the starter and have it tested?
Wednesday, March 13th, 2019 AT 6:03 PM (Merged)
BILLYMAC
  • 2,204 POSTS
I would put a new set of batt terminals and clean batt post if this don, t fix it prob starter
MAXOHMAX
  • FORD RANGER
1998 ford ranger 2.5 L, 4 cyl 160,000 mi. I put a new battery in my truck in the dark and crossed the cables for about 2 sec. Now my ac compresser and the alltanater does not come on. NO power going to the wires. What could have burned up?
BLACKOP555
  • 10,371 POSTS
I believer you fried the relay by crossing the wires wrong. Have it tested
MAXOHMAX
Thats what I figured couse it did not blow no fueses. I thank you for your imput.
BLACKOP555
  • 10,371 POSTS
No problem
CHADDTODD
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 210,000 MILES
The battery in my 94 ford ranger wont charge. The battery is new and the alternator tested good. Does the solenoid have anything to do with this? I checked all fuses and wire harnesses.
WRENCHTECH
  • 20,758 POSTS
What is the charging voltage across the battery with the engine idling and no accessories on?
CHADDTODD
About ten volts. The battery is new and the battery guage drops as it runs. Battery was fully charged when I put it in and the alternator was bench tested.
WRENCHTECH
  • 20,758 POSTS
Check for power at the main terminal with the black/orange wire with the key OFF.
Do you have power there?
Also check the 15amp alternator fuse in the engine compartment fuse box.
CHADDTODD
Yes. The fuse is good.
FPDP080109
  • 1996 FORD RANGER
  • 4 CYL
  • 155,000 MILES
I have the above truck I have changed the alternator which tests fine the battery is good and the wiring harness from the alternator is good no shorts and connections are good battery not charging what do I check or what is the possible problem
Next step is to check fuse no.15 and 17 15amp fuse and the charge indicator
WRENCHTECH
  • 20,758 POSTS
And how about the main terminal power?
TREMOR002000
  • 1995 FORD RANGER
  • 4 CYL
  • 187,800 MILES
I returned back to my truck after having it parked for 2 weeks to find it wouldn't start. I wasn't terribly surprised since it had been so cold. I had no problems with it before parking it. We jumped it off and the voltage needle jumped up and down rapidly. Got it home and left it running with everything off for about 45 min then shut it off and it wouldn't refire. The next morning I put it on the charger. That afternoon it still wouldn't start. Jumped it off and took it to where I bought my battery and was told it was the alternator. Have had that load tested and is fine. When I try to start it I sometimes lose everything inside the truck for a while. Then I will get this clicking coming from the fuse panel inside the truck.
RANGERDANGER17
  • 224 POSTS
Check battery connections take them off and clean only the areas the that must connect for electricty if that doesnt fix it have you battery tested (advance auto) make sure to check all your wires around solenoid starter to make sure nothing is draining the battery
i think it is a combination of both a bad wire draining it and a bad battery check all your fuses under the hood and the the dash
SHABUGZ
  • FORD RANGER
Have a 2000 ford ranger trailhead p/up w/3.0 and 78000 miles. First started by bucking on/off while driving and then straighten out and drive smooth. Then it would be going down rd. And shut off, at this time I would switch ignition key back to off and then forward to on and it would run smooth as silk. This occured periodically until it died last time and wouldnt start back and bat. Was dead. Has new bat., Alt, (not rebuilt), and terminals. With engine jumped and running on alt. (Bat. Dead when jumped of course so has to be running smooth by alt. After jump) pull cable off either side of bat. Motor dies. This list is whats happened since this started. Horn out, when use rt. Turn sig. Speedo. Needle erratic. Doesnt do on left sig. Temp guage only one working. And sometimes, not every time, you jump it then rev motor w/pedal as smooth as silk and other times push acc. Pedal down and (nothing) but it will return to smooth idle everytime whether revs or not. Have 12.5 volts on bat. Not running.15 to 16 volts going thru bat. From alt. When running(however bat being jumped alt. Putting out more). Same volts out of charge line on alt. All volt meter cks. On and off ck. Out to specs on voltmeter. Im beginning to think ign. Switch since every grnd. I could find anywhere in ign. System ckd. Out. Where next?
RAYHUT
  • 134 POSTS
Repalce your altinator, voltage regulator, battery and coil.
