Engine running rich
RANDSAND
  • 2004 FORD RANGER
  • 6 CYL
  • 4WD
  • 42,000 MILES
Hi:
My 04 Ranger 4.0 42K miles is running rich on both banks. The truck runs well. Idle is a little high when I first start it up but within a min or two it is back down. Slight hesitation when I start out, but overall it runs well.
I have cleaned out the throttle body and cleaned the MAF. The MAF was very dirty. I am not sure If I got it 100% clean using electrical cleaner. New airfilter was installed. The codes are back on. Any suggestions?
Thanks!
Tuesday, September 29th, 2009 AT 9:07 AM
  • 108,300 POSTS
What codes are you getting?
Wednesday, October 28th, 2009 AT 10:50 AM
RANDSAND
  • 7 POSTS
The codes I am getting are rich left bank and rich right bank.
Monday, November 2nd, 2009 AT 7:06 AM
  • 108,300 POSTS
It sounds like there is a problem with the MAF sensors cleaning doesn't work most of the time or the temp sensor. Have you had them checked? Also, when I say "Temp Sensor" I am referring to the ambient air temp sensor not the sending unit.
Monday, November 2nd, 2009 AT 7:49 AM
RANDSAND
  • 7 POSTS
Update I got a new MAF for $109.00fixed the problem
Thanks!
Monday, November 2nd, 2009 AT 7:55 AM
GOLDENMARVEL
  • 2003 FORD RANGER
  • V6
  • 4WD
  • 161 MILES
Truck is running rich. Took it to Ford dealership out on machine showing no codes. What could the problem be?
Tuesday, November 26th, 2019 AT 6:50 PM (Merged)
STEVE W.
  • 13,011 POSTS
How do you know the engine is running rich? Fuel smell? Poor mileage? Black smoke?
When was the last time it had a tune up? It sounds like you have a MAF sensor that needs to be replaced. When these sensors go bad they sometimes do not trigger a code.
GOLDENMARVEL
The machine has put new fuel pump new plugs and wires new oil change and filter. But it still running to rich with no codes. What else could it be?
STEVE W.
  • 13,011 POSTS
How do you know it is running rich? If there are no codes saying it is rich then what makes you think it is? Were the plugs carbon covered? Was the fuel pressure tested as high? What is showing that it is running rich? Have the injectors been tested for flow rate? Without knowing what you are seeing as the symptoms of it running rich there is no way to answer the question. You could throw a lot of parts at it and never repair it.
JIS001
  • 3,408 POSTS
  • 2003 FORD RANGER
  • 6 CYL
  • 116,000 MILES
2003 Ford Ranger 3.0L engine, automatic.
I have this truck running full rich (11% CO) with 2 trouble codes. PO2196 and PO2298 for both banks oxygen sensor running full rich. I checked mass air flow sensor and looks ok at about 5.4 pounds per minute. Replaced fuel pressure regulator and no change. Checked fuel pressure and found at 66 psi/idle withing specs. Checked compression. Good compression. Checked ECT sensor and working normal. Checked circuits for all 3 O2 Sensors and checked out fine. Disconnected mass air flow sensor to see if it changes and no changes observed. Disconnected ECT sensor with same results. Live data shows fuel trim at -21 on both banks indicating it is trying to lean out mixture. Also this is what is whats throwing me off. Truck starts fine everytime?Replaced the ECM after above fault tracing and no change. Did I overlook a step? Any help would be apreciated.
DOCFIXIT
  • 18,828 POSTS
Hi
Well you have covered about everything other stuff that can cause faults leaking injectors, see if pressure hold after engine off also high fuel pressure what is pressure off idle? PCV inop and EGR gasket leak and unseated and sealed oil stick and intake restriction and oil overfilled.
Hope this helps
Thanks for donate
JIS001
  • 3,408 POSTS
I never did let you know what the final results were here for the archives? I threw in the white flag on this one and had customer take it in to the dealership. It turned out customer had replaced the engine but had a different intake on here. So it had an internal vaccum leak. The dealership installed the correct intake and problem was fixed. Thanks for all your help.
ALECAT
  • 2002 FORD RANGER
  • 6 CYL
  • 12,000 MILES
I have replaced 3 O2 sensors and the engine doesn't seem to run rich at rpm's below 3000. At 3000 the engine hesitates and begins to run rich with black smoke coming from the exaust.
Tuesday, November 26th, 2019 AT 6:51 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Check the engine coolant temp sensor, Fuel pressure, with particular attention to the pressure regulator...or cloggeg return line.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
ZP3DESIGN
  • 2003 FORD RANGER
  • 6 CYL
  • 70,000 MILES
My otherwise good running Ford Ranger with 3.0 V6 started up and ran very rich (black exhaust smoke) rough idle/poor performance. This occurred after a hot soak. High 90 degrees. We see hotter weather. Next time I started problem gone. Scanner showed no codes. Passed engine off and on test. Just made a 30 mile trip with no problems. I'm getting ready to go on a road trip and wondering if anybody has seen this behavior and what to check.
Thank you
Bob
Hi zp3design, Welcome to 2carpros and TY for the donation
Could be an intermittent problem with one of the following causing it to run rich.
1. Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2. Defective Oxygen Sensors.
3. Leaking injectors and fuel pressure regulator.
4. Coolant temperature sensor out of calibration.
5. Restricted air intake system.
HRAOOF
  • 2001 FORD RANGER
  • 185,000 MILES
Does the fuel relay switch effect the starting of truck
Check the following:
