1989 Ford Ranger Temp gauge
MICKEYADAMS
  • 1989 FORD RANGER
Engine Cooling problem
1989 Ford Ranger 4 cyl Two Wheel Drive Manual
Temp guage isn't working, suspect sending unit. Where is it located as I've been told it has two?
Do you
have the same problem?
Thursday, August 5th, 2010 AT 11:53 AM
BLUELIGHTNIN6
  • EXPERT
Hello and thanks for donating
Your vehicle has a coolant temperature sensor as well as a coolant temperature sending unit. The sending unit is used for the gauge, the sensor used for the cooling fans. The sending unit for the 2.3L is on the left rear of engine, above the oil filter. For the 2.9L it is on the intake manifold, below the throttle body.
Thursday, August 5th, 2010 AT 7:12 PM
Recommended Guides
