disable the alarm system
2006 FORD MUSTANG
55,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEWHAVEN
How do I disable the alarm system, (horn Blowing) in my 06 mustang convertible? It goes off too often and is so loud it is un nerving... simple instructions please, I am not a mechanic.. thank you
Dec 9, 2008 at 1:51 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,209 POSTS
If you have an aftermarket alarm then you must remove the box under the dash and reconnect the interruption wires.
If it is a factory alarm it is difficult to bypass. It is better to just fix it. You will need to take it to the dealer to have it reprogrammed for about $120.00
Here is more information on how to check the system out
The alarm on your vehicle has it's own horn system. Behind the panel on the right side of trunk. It's also connected to the car horn so you would have to unplug both, I do not know if you unplug the Alarm's horn if it will have an effect on the alarm system . You need to have the vehicles SJB (smart junction box) read by computer for faults.
PINPOINT TEST D: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY - ANTI-THEFT ALARM HORN AND TRAFFIC HORN CONTINUOUSLY ON
D1 CHECK FOR CORRECT SJB OPERATION
Disconnect all the SJB connectors.
Check for:
corrosion
pushed-out pins
Connect all the SJB connectors and make sure they seat correctly.
Operate the system and verify the concern is still present.
Is the concern still present?
Yes : INSTALL a new SJB. REFER to MULTIFUNCTION ELECTRONIC MODULES. CLEAR the DTCs. REPEAT the self-test.
No : The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
DESCRIPTION AND OPERATION
Anti-Theft
The perimeter alarm system consists of:
anti-theft alarm horn
traffic horn
front door ajar switches
door lock control switch
anti-theft hood switch
luggage compartment lid ajar switch
convertible top ajar switch (if equipped)
luggage compartment lid anti-theft inhibit switch
door disarm switch (SET/RESET)
remote keyless entry (RKE) transmitter
ignition switch
intrusion and inclination sensor
smart junction box (SJB)
powertrain control module (PCM)
controller area network (CAN)
The anti-theft perimeter protection feature is controlled by the SJB.
NOTE:The convertible top, the luggage compartment lid, and all doors must be closed for the interior motion sensing feature to activate.
NOTE:All the windows must be closed for correct motion sensing operation.
NOTE:The inclination sensing feature must be disarmed before raising the vehicle on a hoist to prevent false alarms.
Perimeter Alarm System
The perimeter alarm system is designed to warn the driver in the event of an unauthorized entry to the vehicle and is also designed to help prevent the unwanted towing of the vehicle. When the vehicle is locked and armed, the perimeter alarm system monitors the following:
doors
hood
movement inside the vehicle
change in vehicle inclination/tilt
If unauthorized activation of the above inputs occurs the system flashes the turn signals and sounds the anti-theft alarm and the traffic horns.
NOTE:The perimeter alarm system includes a motion detection system that monitors the vehicle interior and a vehicle inclination sensor that detects changes in vehicle inclination.
The interior motion detection and vehicle inclination sensing system operate only when the vehicle is locked using the RKE transmitter or when using the door lock control switch with the accompanying door open and all the doors are then closed. For vehicles with a convertible top, the top must be in the fully closed and latched position for the interior motion sensing system to arm. If the vehicle is locked using the key in the driver door lock cylinder, the system monitors the doors, luggage compartment lid, and hood but the interior motion and the vehicle inclination sensing does not arm. Do not arm the interior motion detection system if movement within the vehicle is likely to occur. Do not arm the vehicle inclination sensing system when the vehicle is in transport. For correct operation of the interior motion detection system, make sure all the windows are closed prior to arming the system. This helps prevent accidental alarm activation due to external influences and makes sure that correct interior motion detection occurs. The interior motion sensing system does not arm if either door is ajar.
Arming the System
When armed, the perimeter alarm system is designed to notify the driver of an unauthorized entry. When unauthorized entry or towing occurs, the system flashes the turn signal lamps and interior lamps and sounds the anti-theft alarm and the traffic horns. The system is ready to arm whenever the key is out of the ignition. Any of the following actions arm the alarm system:
Pressing the RKE transmitter lock control 1 time to arm the system.
Locking all the doors using the door lock control switch while the driver or passenger door is open and then closed.
Locking the driver door with the key in the driver door lock cylinder (this does not arm the interior motion or vehicle inclination sensing systems).
If all the closures (doors, luggage compartment lid, and hood) are closed, the turn signal lamps flash once. If the vehicle is locked again within 3 seconds, the vehicle locks again, the turn signal lamps flash and the horn chirps. If any closure is not properly closed, the turn signal lamps do not flash and the horn chirps twice. The system waits 20 seconds after locking before triggering an alarm. After the 20 second pre-arm phase, the door lock control switch is disabled (if door lock inhibit function is configured on) to further protect the vehicle.
NOTE:Deactivating a sounding alarm by pressing the PANIC button on the RKE transmitter returns the system to an armed state.
NOTE:Unlocking the luggage compartment inhibits the interior motion and inclination sensing systems, but the perimeter alarm system continues to monitor the doors and hood. Once the luggage compartment lid is closed the interior motion sensing systems are again monitored.
Disarming the System
The perimeter alarm system can be disarmed by any of the following actions:
unlocking the doors using the RKE transmitter.
Unlocking the driver door with the key in the driver door lock cylinder.
Turning the ignition switch to the ON position with a programmed coded ignition key.
Mar 9, 2017 at 2:01 PM
HUNTERSRULE07
Electrical problem
1998 Ford Mustang 6 cyl Two Wheel Drive Manual 82300 miles
my theft light on the dash board is going off and the car wont start. Ford says my transponder is bad and wants to charge 400-500 for a new transponder? Is there any possible way to DISCONNECT or BYPASS the alarm so I can get my car running again?
Mar 9, 2017 at 2:02 PM (Merged)
MERLIN2021
  • 17,250 POSTS
The only thing you can try is open the door lock with the key, then turn the ignition to on, the light should turn on solid for a second or two then turn off, if this happens the car will start.
KATI_N11
How do I disconnect my car alarm? I lost my fob and that's the only way I know how to turn the alarm off (by pushing the unlock button) and I've been having other problems with the alarm so I just want to turn it off. I can't start my car because of the alarm. I need to disable the alarm (not just the honking noise).
Mar 9, 2017 at 2:04 PM (Merged)
CARADIODOC
  • 34,308 POSTS
The alarm is built into multiple computers. If it was possible to disable it, a car thief could do that too, so there would be no point to it except to keep owners out of their cars. Most factory alarms are also disabled by unlocking a front door with the key. When that doesn't work, there's usually a broken wire between the door hinges, or less-commonly, a defective switch in the door latch.
TAZONE99
  • 9 POSTS
Mustang 1996 v8 4,6 ford alarm fitted as part of car.cuts engine out when its started after i changed the indicator multi function switch. I did not disconnected the battery unfortunately causing the alarm to think the car was being stolen don't know how to reset the alarm?
Alarm cuts engine out after changing indicator switch on column.
Great Site !
RIVERMIKERAT
  • 6,110 POSTS
How have you determined that it's the alarm? Chances are something in the ignition switch was shorted when you changed out the multifunction switch.
TAZONE99
  • 9 POSTS
i know its they anti theft alarm because it flashes it up on the dash board display.the engine starts then the alarm cuts it out
RIVERMIKERAT
  • 6,110 POSTS
Does your remote arm and disarm the system?
TAZONE99
  • 9 POSTS
dont have a remote i think its suposed to reset on the door lock when u lock the car but it wont reset
TAZONE99
  • 9 POSTS
no remotewith car
RIVERMIKERAT
  • 6,110 POSTS
The vehicle security systems I've ever installed required either a remote or a keypad to arm and disarm the system. The keys lock and unlock the doors, but the security system requires an electrical impulse of some sort to activate.
Ok, found some information that may be of assistance to you:
TESTING
Before performing any tests on anti-theft system, check the following items to eliminate common
problems:
• Hood/trunk/liftgate properly aligned.
• Door locks not binding.
• Fuses not blown.
• Loose or corroded connections.
• Damaged wiring harness.
• Damaged anti-theft control module.
Horn, headlights, hazard flashers, interior lights, trunk lights, power door locks and remote
keyless entry system operation.
LOCK SWITCH TESTING
Remove lock switch. Measure resistance between switch terminals. With switch in neutral position,
resistance should be 25 k/ohms or greater. With switch in unlock position, resistance should be less
than 200 ohms. Replace switch if resistance is not within specification.
FLASH CODE TEST
NOTE: Use this test to quickly identify a short to ground in the door lock
cylinder switches, hood switch, ignition lock anti-theft switch or their
associated circuits.
Turn ignition switch to ACCESSORY position check THEFT indicator lamp. If lamp lights
steadily for 10 seconds, check ignition lock anti-theft switch and circuit No. 936 (Dark
Green/White) wire. If lamp operates normally, go to next step.
1.
Activate power door unlock button 5 times within 10 seconds. Count number of flashes of the
anti-theft warning indicator lamp. If there is only one flash, system is normal, go to PINPOINT
TEST DIRECTORY TABLE . If there are 2 flashes displayed, go to next step. If there are 3
flashes displayed, go to step 4). If there are 4 flashes displayed, go to step 5).
2.
Two flashes indicate door lock cylinder switch input shorted. Repair or replace door lock
cylinder switches and circuit No. 25 (Dark Green/Purple wire).
3.
Three flashes indicate hood anti-theft switch and/or trunk lock cylinder switch input shorted.
Repair or replace hood anti-theft switch and/or trunk lock cylinder switch and circuit No. 23
(Tan/Light Green wire).
4.
Four flashes indicate door lock cylinder switch, hood anti-theft switch and/or trunk lock
cylinder switch input shorted. Repair or replace door lock cylinder switch, hood anti-theft
switch and/or trunk lock cylinder switch and related circuits.
5.
Fig. 1: Anti-Theft Control Module Connector Pin ID (Mustang)
Courtesy of FORD MOTOR CO.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 1 of 7
PINPOINT TEST DIRECTORY
Use the following directory to determine individual pinpoint tests for anti-theft system.
Symptom Pinpoint Test
Alarm Does Not Arm Properly A
Alarm Does Not Disarm Properly B
Alarm Does Not Activate Properly C
Starter Will Not Crank D
Alarm Indicator Light Always On E
Alarm Indicator Light Does Not Work F
Horn & Headlights Are Always On G
System Triggers False Alarms H
PINPOINT TEST A - ALARM DOES NOT ARM PROPERLY
Start vehicle, then turn ignition off. Disconnect Anti-Theft Control Module connectors. With
doors closed, measure voltage at Anti-Theft Control Module connector C2, terminal No. 14.
See Fig. 1 . If voltage is less than 9 volts, go to step 3). If voltage is more than 9 volts, go to
next step.
1.
Disconnect both courtesy lamp switches. Measure voltage at Anti-Theft Control Module
connector C2, terminal No. 14. If voltage is less than 9 volts, check door courtesy switches and
retest system. If voltage is more than 9 volts, repair short to battery power in circuit No. 24
(Dark Blue/Orange wire) and retest system.
2.
Disconnect Anti-Theft Control Module connectors. Measure resistance between connector C1,
terminal No. 6 (Dark Green/Purple wire) and connector C2, terminal No. 26 (Black/White
wire). If resistance is less than 100 ohms, go to next step. If resistance is more than 100 ohms,
go to step 6).
3.
Disconnect driver and passenger door lock cylinder switches. Measure resistance between
connector C1, terminal No. 6 (Dark Green/Purple wire) and connector C2, terminal No. 26
(Black/White wire). If resistance is less than 100 ohms, repair short to ground in circuit No. 25
(Dark Green/Purple wire) and retest system. If resistance is more than 100 ohms, go to next
step.
4.
Measure resistance across driver door lock cylinder switch terminals, repeat for passenger side.
If resistance is less than 100 ohms, replace door lock cylinder switch and retest. If resistance is
more than 100 ohms, go to next step.
5.
Disconnect Anti-Theft Control Module connectors and Remote Keyless Entry Module
connector. Turn ignition off. Measure voltage to ground (terminal No. 26, Black/White wire)
between Anti-Theft Control Module connector C2, terminal No. 8 (Red/Orange wire),
connector C1, terminal No. 7 (Pink/Orange wire), connector C2, terminal No. 9 (Pink/Black
wire) connector C1, terminal No. 4 (White/Purple wire). If any or all voltages are more than 2
volts, repair short to battery power in circuit No. 117 (Pink/Black wire), No. 118 (Pink/Orange
wire), No. 163 (Red/Orange wire) and/or No. 296 (White/Purple wire) and retest system. If all
voltages are less than 2 volts, go to next step.
6.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 2 of 7
Turn Ignition off. Connect jumper wires between Remote Keyless Entry Module connector C3
terminal No. 16, No. 3, No. 6 and ground. See KEYLESS ENTRY SYSTEM - REMOTE
article. Measure resistance between Anti-Theft Control Module connector C2, terminal No. 9
(Pink/Black wire) and terminal No. 26 (Green Yellow/Red wire). Repeat procedure between
Anti-Theft Control Module connector C1, terminal No. 7 (Pink/Orange wire) and connector C2.
terminal No. 8 (Red/Orange wire). If resistance is more than 100 ohms on any terminal, repair
open on circuit No. 117 (Pink/Black wire), No. 118 (Pink/Orange wire) and/or No. 163
(Red/Orange wire) and retest system. If all readings are more than 100 ohms, go to next step.
7.
Measure resistance to ground (terminal No. 26, Green Yellow/Red wire) between Anti-Theft
Control Module connector C1, terminal No. 7 (Pink/Orange wire) connector C2, terminal No. 8
(Red/Orange wire) and connector C2. terminal No. 9 (Pink/Black wire). If resistance is less
than 100 ohms, repair short to ground in circuit No. 117 (Pink/Black wire), No. 118
(Pink/Orange wire) and/or No. 163 (Red/Orange wire) and retest system. If all readings are
8.
Measure voltage at Anti-Theft Control Module connector C1, terminal No. 7 (Pink/Orange
wire) and connector C2, terminal No. 26 (Green Yellow/Red wire). If voltage reading is more
than 9 volts, go to step 11). If reading is less than 9 volts, go to next step.
9.
Check 20-amp inline fuse (from fuse junction panel). If fuse is blown, replace fuse and retest
system. If fuse is good, repair open circuit No. 196 (Dark Blue/Orange wire) and test system.
10.
Reconnect Anti-Theft Control Module connectors and Remote Keyless Entry Module
connector. Ensure voltage at Anti-Theft Control Module connector C1, terminal No. 7
(Pink/Orange wire) is less than 2 volts and that a momentary battery voltage signal is present at
connector C2, terminal No. 9 (Pink/Black wire) when doors are locked via keyless entry lock
code (7/8 and 9/0) or remote transmitter LOCK button. If voltage reading is correct, replace
Anti-Theft Control Module and retest system. If voltage reading is not correct, go to next step.
11.
Disconnect Anti-Theft Control Module connectors. Ensure voltage at Anti-Theft Control
Module connector C1, terminal No. 7 (Pink/Orange wire) is less than 2 volts and that a
momentary battery voltage signal is present at connector C2, terminal No. 9 (Pink/Black wire)
when doors are locked via keyless entry lock code (7/8 and 9/0) or remote transmitter LOCK
button. If voltage reading is correct, replace Anti-Theft Alarm Control Module and retest
system. If voltage reading is not correct, check for malfunction in Keyless Entry System or
remote transmitter. See KEYLESS ENTRY SYSTEM - REMOTE article.
12.
PINPOINT TEST B - ALARM DOES NOT DISARM PROPERLY
Start vehicle, then turn ignition off. Disconnect Anti-Theft Control Module connectors and
Remote Keyless Entry Module connector. Connect a jumper wire between Remote Keyless
Entry Module connector C3, terminal No. 3 (Red/Yellow wire) and terminal No. 6 (Black
wire). See Fig. 1 . Measure resistance between Anti-Theft Control Module connector C2,
terminal No. 8 (Red/Orange wire) and terminal No. 26 (Black/White wire). Repeat procedure
for Anti-Theft Control Module connector C1, terminal No. 7 (Pink/Orange wire) and terminal
No. 26 (Black/White wire). If resistance is less than 100 ohms for both readings, go to next
step. If resistance is more than 100 ohms for either readings, repair open in circuit No. 163
(Red/Orange wire) or circuit No. 118 (Pink/Orange wire) and retest system.
1.
Turn ignition on. Measure voltage between Anti-Theft Control Module connector C1, terminal
No. 7 and terminal No. 26 (Black/White wire). If voltage is more than 9 volts, go to next step. If
voltage is less than 9 volts, go to step 4)
2.
Check 10-amp fuse No. 5 from fuse junction panel. If fuse is bad, replace fuse and retest
system. If fuse is good, repair open in circuit No. 296 (White/Purple wire) and retest system.
3.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 3 of 7
Connect Remote Keyless Entry Module connector. Unlock door lock with key, leaving key
rotated to unlock position. Measure resistance between Anti-Theft Control Module connector
C1, terminal No. 6 (Dark Green/Purple wire) and terminal No. 26 (Black/White wire). Repeat
procedure for passenger door. If both readings are more than 100 ohms, go to next step. If both
readings are less than 100 ohms, go to step 6).
4.
Disconnect driver door lock cylinder switch. Check for continuity across door lock cylinder
switch terminals while turning lock cylinder with key. Repeat procedure for passenger door
lock cylinder switch. If there is continuity with key in unlock position and no continuity with
key in lock position, repair open in circuit No. 25 (Dark Green/Purple wire) and retest system.
If continuity is not as stated above, replace damaged door lock cylinder switch(es) and retest
system.
5.
Connect Anti-Theft Control Module connectors. Ensure voltage at Anti-Theft Control Module
connector C2, terminal No. 9 (Pink/Black wire) is less than 2 volts and that a momentary
battery voltage signal is present at connector C2, terminal No. 8 (Red/Orange wire) when doors
are unlocked via keyless entry unlock code or remote transmitter UNLOCK button. If voltage
reading is correct, replace Anti-Theft Control Module and retest system. If voltage reading is
incorrect, go to next step.
6.
Module connector C2, terminal No. 9 (Pink/Black wire) is less than 2 volts and that a
momentary battery voltage signal is present at connector C2, terminal No. 8 (Red/Orange wire)
when doors are unlocked via keyless entry unlock code or remote transmitter UNLOCK button.
If voltage reading is correct, replace Anti-Theft Control Module and retest system. If voltage
reading is incorrect, problem is in Remote Keyless Entry System. See appropriate KEYLESS
7.
PINPOINT TEST C - ALARM DOES NOT ACTIVATE PROPERLY
Start vehicle, then turn ignition off. Disconnect Anti-Theft Control Module connectors. Open
hood. Measure resistance between Anti-Theft Control Module connector C1, terminal No. 5
(Tan/Light Green wire) and connector C2, terminal No. 26 (Black/White wire). See Fig. 1 . If
resistance is less than 100 ohms, go to step 3). If resistance is more than 100 ohms, got to next
step.
1.
Disconnect hood anti-theft switch. Measure resistance between hood anti-theft switch terminals
while depressing and releasing switch plunger. If resistance is more than 100 ohms when switch
is depressed and less than 100 ohms when switch is released, switch is okay. Repair open in
circuit No. 23 (Tan/Light Green wire). If resistance is not correct, replace hood anti-theft switch
and retest system.
2.
Connect Anti-Theft Control Module. Open driver door only. Measure voltage between Anti-
Theft Control Module connector C2, terminal No. 14 (Dark Blue/Orange) and connector C2,
terminal No. 26 (Black/White wire). Repeat procedure with passenger door. If voltage is more
than 9 volts, go to step 5). If voltage is less than 9 volts, go to next step.
3.
Disconnect driver door courtesy light switch. Connect a jumper wire between courtesy light
wiring harness terminals. Measure voltage between Anti-Theft Control Module connector C2,
terminal No. 14 (Dark Blue/Orange wire) and connector C2, terminal No. 26 (Black/White
wire). Repeat procedure with passenger door. If voltage is more than 9 volts, repair or replace
courtesy light switches and retest system. If voltage is less than 9 volts, repair open in circuit
No. 24 (Dark Blue/Orange wire) and retest system.
4.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 4 of 7
Arm alarm system with window down. Reach inside and open door using inside door handle. If
alarm triggers, system is okay. If alarm does not trigger, replace Anti-Theft Control Module and
retest system.
5.
PINPOINT TEST D - STARTER WILL NOT CRANK
NOTE: PINPOINT TEST D is only for conditions where the engine will not crank
at all. If models with 4.6L engines will crank for one second and then
stall, see ANTI-THEFT SYSTEM - PASSIVE article.
Arm, then disarm system. Attempt to start engine. If engine starts, system is okay. If engine will
not start, go to next step.
1.
Turn ignition off. Disconnect Anti-Theft Control Module connectors. Connect a jumper wire
between Anti-Theft Control Module connector C2, terminal No. 12 (White/Pink wire) and
connector C2, terminal No. 26 (Black/White wire). See Fig. 1 . If engine does not start, go to
next step. If engine would not start in step 1) but starts now, replace Anti-Theft Control Module
and retest system.
2.
Remove jumper wire and measure voltage between Anti-Theft Control Module connector C2,
terminal No. 12 (White/Pink wire) and connector C2, terminal No. 26 (Black/White wire). If
voltage is more than 9 volts, go to next step. If voltage is less than 9 volts, repair open in circuit
No. 33 (White/Pink wire).
3.
Turn ignition off. Connect a jumper wire between Anti-Theft Control Module connector C2,
terminal No. 12 (White/Pink wire) and terminal No. 24 (Red/Light Blue wire). Measure voltage
across starter motor solenoid terminals while turning ignition to start. If voltage is more than 9
volts, repair or replace starter motor solenoid and retest system. If voltage is less than 9 volts,
repair open in circuit No. 32 (Red/Light Blue wire) and retest system.
4.
PINPOINT TEST E - ALARM INDICATOR LIGHT ALWAYS ON
NOTE: On models with 4.6L engines, Alarm Indicator Light is shared by Anti-
Theft Alarm System and Passive Anti-Theft System. The Anti-Theft
Alarm System uses the indicator light when ignition is off and the
Passive Anti-Theft uses the indicator light when ignition is in run or
start. See ANTI-THEFT SYSTEM - PASSIVE article.
Remove key from ignition. With doors closed and unlocked, observe alarm indicator light. If
light is not flashing continuously, go to next step. If light is flashing continuously, go to step 3).
1.
With key removed from ignition and doors closed and unlocked, observe alarm indicator light.
If light is on continuously, go to step 5). If light is not on continuously, system is okay.
2.
Disconnect Anti-Theft Control Module connectors. Close both doors. Measure voltage between
Anti-Theft Control Module connector C2, terminal No. 14 (Dark Blue/Orange wire) and
connector C2, terminal No. 26 (Black/White wire). See Fig. 1 . If voltage is more than 9 volts,
go to next step. If voltage is less than 9 volts, replace Anti-Theft Control Module and retest
system.
3.
Disconnect driver door and passenger door courtesy light switches. Measure voltage between
connector C2, terminal No. 26 (Black/White wire). If voltage is more than 9 volts, repair short
4.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 5 of 7
to battery power in circuit No. 24 (Dark Blue/Orange wire) and retest system. If voltage is less
than 9 volts, repair or replace courtesy light switch(es) and retest system.
Disconnect Anti-Theft Control Module connectors. If alarm indicator light goes out, replace
Anti-Theft Control Module and retest system. If alarm indicator light does not go out, repair
short to ground in circuit No. 343 (Dark Blue/Light Green wire) and retest system.
5.
PINPOINT TEST F - ALARM INDICATOR LIGHT DOES NOT WORK
Start vehicle, then turn off. Disconnect Anti-Theft Control Module connectors. Connect a
jumper wire between Anti-Theft Control Module connector C1, terminal No. 15 (Dark
Blue/Light Green wire). See Fig. 1 . If light turns on, replace Anti-Theft Control Module and
retest system. If light does not turn on, go to next step.
1.
Check 15-amp INT LPS fuse and anti-theft indicator bulb. If either are bad, replace and retest
system. If fuse and bulb are good, repair circuit No. 54 (Light Green/Yellow wire) and/or
circuit No. 343 (Dark Blue/Dark Green wire) and retest system.
2.
PINPOINT TEST G - HORN & HEADLIGHTS ARE ALWAYS ON
Disconnect anti-theft control module. If horn turns off, replace anti-theft control module and
retest system. If horn remains on, service horn circuit and retest system.
1.
Disconnect anti-theft control module. If low beam headlights turn off, replace anti-theft control
module and retest system. If low beam headlights remain on, repair short to battery power in
circuit No. 13 (Red/Black wire). If parklights remain on, repair short to battery power in circuit
No. 14 (Brown wire). Retest system.
2.
PINPOINT TEST H - SYSTEM TRIGGERS FALSE ALARMS
NOTE: Ensure that system triggers false alarms on a regular basis before
performing steps 2) through 5).
Disconnect anti-theft control module. Close doors and hood. Measure resistance between Anti-
Theft Control Module connector C1, terminal No. 5 (Tan/Light Green wire) and connector C2,
terminal No. 26 (Black/White wire). If resistance is more than 100 ohms, go to step 7). If
1.
Open hood and trunk. Disconnect hood anti-theft switch and trunk anti-theft switch. Measure
resistance between Anti-Theft Control Module connector C1, terminal No. 5 (Tan/Light Green
wire) and connector C2, terminal No. 26 (Black/White wire). If resistance is more than 100
ohms, go to next step. If resistance is less than 100 ohms, repair short to ground in circuit No.
23 (Tan/Light Green wire) and retest system.
2.
Measure continuity between hood anti-theft switch terminals while depressing and releasing
switch plunger. If continuity is not present when switch is depressed and is present when switch
is released, go to next step. If continuity is not correct, replace hood anti-theft switch and retest
system.
3.
Reconnect hood switch and close hood. Measure resistance between Anti-Theft Control Module
connector C1, terminal No. 5 (Tan/Light Green wire) and connector C2, terminal No. 26
(Black/White wire). If reading is 100 ohms or more, go to next step. If reading is less than 100
ohms, adjust hood switch so that switch plunger is depressed when hood is closed. Retest
system.
4.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 6 of 7
Check trunk lock cylinder switch for short to ground or intermittent short to ground by
measuring continuity between trunk lock cylinder switch terminals. Jiggle switch wiring and
lock cylinder with keys. If continuity or intermittent continuity, indicating short to ground, is
not present, replace Anti-Theft Control Module and retest. If continuity or intermittent
continuity is present, replace trunk lock cylinder switch and retest system.
5.
Connect Anti-Theft Control Module connectors and close all doors. Measure voltage between
Anti-Theft Control Module connector C2, terminal No. 14 (Dark Blue/Orange) and terminal
No. 26 (Black/White wire). If voltage is less than 9 volts, go to step 8). If voltage is more than 9
6.
Anti-Theft Control Module connector C2, terminal No. 14 (Dark Blue/Orange) and connector
C2, terminal No. 26 (Black/White wire). If voltage is more than 9 volts, repair short to battery
power in circuit No. 24 (Dark Blue/Orange wire) and retest system. If voltage is less than 9
7.
Turn ignition off. Measure resistance between Anti-Theft Control Module connector C2,
terminal No. 10 (Dark Green/White wire) and terminal No. 26 (Black/White wire). If resistance
is 150-175 ohms, replace Anti-Theft Control Module only if steps 1) through 4) have been
performed. Retest system. If resistance is not 150-175 ohms, replace ignition lock cylinder
tamper switch and retest system.
8.
© 2008 Mitchell Repair Information Co., LLC.
ANTI-THEFT SYSTEM -1996 Ford Mustang Page 7 of 7
If it's a factory system, contact your local Ford dealership.
TAZONE99
  • 9 POSTS
changed electric switch in car. now alarm cuts engine out how do u reset alarm.door key does not reset alarm v8 4.6 gt 1996
RIVERMIKERAT
  • 6,110 POSTS
What switch did you change?
TAZONE99
  • 9 POSTS
realy good info thanks ,where is the anti theft controll module on the car. also on the ignition block theres a device with a black wire wich seams to hook in on top of the ignition key block any idea what this does
TAZONE99
  • 9 POSTS
multifunction switch on collum 1996 mustang alarm cut out
RIVERMIKERAT
  • 6,110 POSTS
Left rear of the trunk. See image. I have also attached a screenshot of a portion of the instrument cluster schematic showing the ignition switch.
RIVERMIKERAT
  • 6,110 POSTS
Did you disconnect the battery prior to changing the switch for some reason?
Is the alarm factory,or aftermarket? If it's aftermarket, do you know what brand and model #? They all have different procedures.
TAZONE99
  • 9 POSTS
well i removed the anti theft unit from the wiring(its in the boot found it with picture you supplied)plug started the engine it still cuts out and flashes theft on the dash same as before,if engine runs but cuts out 2 sec later with or without the alarn connected .any idea what unit is causing problem
TAZONE99
  • 9 POSTS
my direct e mail is tazone99@yahoo.co.uk
RIVERMIKERAT
  • 6,110 POSTS
See if you can rent or borrow a scan tool and scan it for fault codes. I'm thinking that the anti theft unit needs to be in the loop to keep it running, but that the unit you have may be defective.
  • 54,209 POSTS
Try resetting the alarm by unlocking the drivers door from the outside.
Thanks for using the site :-)
BIGSWIG
Ok.. well.. it isnt my car and im not 100% sure of exactly what happens... but ehre it is.
First off, the car starts and works just fine but it SEEMS random as to when it happens, sometimes when i go to get in the remote will not work to unlock the doors at all, and if i unlock the driver side door, the alarm goes off and disables teh ignition. so i cant restart it. I found a temporary fix: take off the red battery wire under the hood, get in the car, turn on the key (like the battery) then go reconnect the red wire and then start the car... but the key will not turn off the alarm by trying to start, or unlocking the door and the cremote doesnt work when the problem happens. It is NOT the key(chip) because ive went and got 3 new keys, and ive also replaced the remote battery and the car battery... any ideas anyone? again this is a 1998 Ford Cobra Mustang
NOS
  • 320 POSTS
this is a shot in the dark you say you have had new key's made. but have you checked to see if you need to have your keyless remotes reprogramed? or you possibly have a short in the drivers door where the wires come from the cab to the door there is a rubber boot where your doorlock wiring and power window wiring and all goes through. dude not even sure i can put you on the right track with this one.(NOS) :? sometimes the get out of sync
BIGSWIG
ah yah ive programed the remotes, ill redo it maybe i screwed up, ill also check for a short, thanks for the suggestions
NOS
  • 320 POSTS
no problem not realy sure if i helped or not but i will keep an eye out for more updates on this one.(NOS)
BIGSWIG
ehh ignore that i tried 2 keys that werent the right keys... so far no more problems and i havent did anything.. im sure the problem will happen again, so still replacing batteries and checking for a short.
TRANSFER
Electrical problem
1998 Ford Mustang V8 Front Wheel Drive Automatic 70,000 miles
EVERYTIME I LOCK MY CAR MY CAR THEFT ALARM GOES OFF...I CANT LOCK IT AT ALL .
HELP....WHAT CAN IT BE?
Mar 9, 2017 at 2:05 PM (Merged)
RACEFAN966
  • 5,029 POSTS
Ok I need to know if your system is an active or passive system. To do this if you don't know you simply call the dealer with you vin number in hand and give them the vin and ask. Get back to me with what you have and I will get you the self diagnostic procedure to figure out what it going on. It may just a door jam switch who know's, but we can find out. Now use the pm button to get directly to me with a personal message and refresh me with what we are doing ok.
TRANSFER
I TRIED TO PM BACK TO RACEFAN 966 BUT YOUR SITE WOULDNT LET ME..SO HOPEFULLY HE SEES MY RESPONSE TO HIS QUESTION. FORD SAYS I HAVE A PASSIVE SYSTEM.
THANKS, DEBBIE
MUSTANGGUY1998
Electrical problem
1998 Ford Mustang V8 Two Wheel Drive Automatic 77982 miles
My 98 Mustang Car alarm has failed me i can set the alarm with the remote and in about 5 minutes or less the alarm goes off. I had a spare key made (one with out the chip) and i think someone used it to try to start the car to see if it would or not. Is there anyway to reset the car alarm?? Please Help Thanks
MERLIN2021
  • 17,250 POSTS
Only way I know of is at Ford! One hour labor, and if you need a key get it there, they will program both...
AGAJESSICA
My car alarm will go off when I'm sitting inside trying to get out. The car will be parked, and my boyfriend and I will go out to my car to smoke a cigarette. We will unlock the car by putting the key in the driver side door, I will then unlock his door from the inside. We get in and lock the doors. When we get out the alarm goes off often but not every time. I want to know what we are doing to trigger it sometimes? Does it have to do what order we open the doors, or is it because we unlock it from the inside to get out? I don't understand.
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online. if it continues have a local pro scan for codes to see if anything is wrong with security system.
