2003 Ford F350 lost of oil preasure
2003 FORD F-350
75,000 MILES • V8 • 4WD • AUTOMATIC
CARLOSGPERULA
vehicle lost preasure during driving,
headf gasket leake was identify; head gaskest replaced.
computer report 1400 psi required; engine starts with 800 and shutdown at 600
it looks like same defficiency
thank you for your help
Dec 15, 2009 at 12:38 PM
BILLYMAC
  • CAR REPAIR CONTRIBUTOR
  • 2,204 POSTS
Hi
well i will have to assume by the pressures you have posted. that you have a powerstroke diesiel.
if this is the case then you have a prob with your high pressure oil pump system. this may be the pump itself or part of the control system that operates this system.
you will need diagnostics on your hp oiling system..
Dec 28, 2009 at 3:58 PM
