Wont start
EXPRESSDEMO
  • 2003 FORD F-350
  • V8
  • 167,000 MILES
6.0 turbo diesel cranks but wont start. If you pump the gas pedal and hold it down sometimes it will start and run perfect. Fuel pump works and has good pressure. All fuses are good truck starts with starting fluid and runs perfect. Will not start without ether
Monday, August 23rd, 2010 AT 4:17 PM
BLACKOP555
  • 10,371 POSTS
Alright. Is there any check engine light codes that are coming up?
First off 6.0's had a problem with the dc/dc convertor in the FICM fuel injector control module failing. There is a technical service bulliten out on it. Good bet would be contacting a ford dealership and explain whats happening and see if they will cover it. If not we can try to go further in. Get back to me if you have a check engine light on and your able to get codes to me and post them in P**** format.
Thanks!
Wednesday, August 25th, 2010 AT 8:45 PM
ROGERBOWSER46
  • 2003 FORD F-350
  • 6.1L
  • V6
  • TURBO
  • RWD
  • 65,000 MILES
Truck sat for over a year, winter and summer. Now, it will not start. The diesel engine specs are listed above.
Friday, October 4th, 2019 AT 3:51 PM (Merged)
HMAC300
  • 48,601 POSTS
Try resetting security system on it battery probably went to low or dead causing it see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,054 POSTS
Hey Roger,
Does the engine crank over? Or it cranking over and not starting? It could be the battery has gone bad because they do not like to sit without being used.
Can you give us more details please so we can continue?
Best, Ken
TORRESLAWNSVC
  • 2003 FORD F-350
  • V8
  • 4WD
  • MANUAL
  • 158,000 MILES
On Sunday, I replaced the starter. Ran the truck all day Monday. On Tuesday morning, the truck started up just fine. Made a stop where I shut the engine off. The truck set for about an hour. Came back and went to start the truck, but no luck. The lights on the instrument panel light up fine. I the problem thought it might be the clutch switch. So I went to town to get the switch. When I returned I tried to the start the truck and it started up just fine. I pulled the truck out of our building and shut it off. Came back about five minutes later to leave and the truck would not start.
BILLYMAC
  • 2,204 POSTS
Hi I would check the terminals on the plug at the clutch switch. Also check the connection and connector on the starter solinoid. The batt cables and terminals clean and tight. If the prob is still there after all this. Then the ignition switch the electronic not key and tumbler. Is most likely bad or out of adjustment. Good luck billymac
ZACH06213
  • 2003 FORD F-350
  • 168,000 MILES
I have a 2003 ford f-350 6.0 diesel I got kinda stuck in the mud put her in 4 wheel drive and reemed on it a little but I didnt exceed about 3 grand I let of the peddel and the truck sputterd a couple times and then stalled out now it will roll over but not start it has a new starter I checked the fuses all good Iunhooked then batteries didnt help it is still pumping fuel just fine I sprayed hether in the air filter and it will run for a second and then stall out any ideas would be appreciated
BLACKOP555
  • 10,371 POSTS
Can you check for codes? I would start by pulling out the egr valve and making sure it is fully closed if not pound it shut put back in and start it. Put in a new egr valve if you find it excessivly carboned. If this is not it check for fuel getting in the secondary fuel bowl. Also do you have a reading on your oil pressure guage when cranking.
MRFIX IT
  • 5 POSTS
  • 2003 FORD F-350
  • 89,000 MILES
Hello I had a 2003 ford f 350 super duty diesel 6.0 I i had a crank no start cook up the scantool and did some diagnostic and found that the pcm needed replacing I ordered one but the parts guy told me I would need a ford vcm to reprogram the pcm before it work I bought one now they're telling me that the vcm does not work on diesel pickup trucks what you I do?
  • 52,797 POSTS
How did you determine the pcm was bad? Expensive guess.
The dealer can program it for you if it is the issue
what was the code?
MRFIX IT
  • 5 POSTS
Wasnt a guess we hook up our bidirectional scan tool got the code diagnostic it using alldata procedures did some testing and after back back checking everything else glow plug, fuses relays, Fuel module, injectors, high pressure oil pump, etc we can to that conclusion and in the caribbean there no ford dealer on the island I already have a vcm but could get it reprogram they said because its diesel and the vcm is not for pickup. Was wondering if there's a vcm just for diesel or some other tool I can buy to do it?
  • 52,797 POSTS
Yes, just for diesel. The numbers must be the same or it will not work.
MRFIX IT
  • 5 POSTS
Ok great do you have a link where I can buy it?
MRFIX IT
  • 5 POSTS
What numbers?
  • 52,797 POSTS
The numbers on the pump. You may need to remove the pump to see the numbers.
Once you have the numbers, then you can persue the issue with e bay or amazon.
MRFIX IT
  • 5 POSTS
Ok thanks so once I get the number I use this to get a vcm just for diesel to reprogram the new pcm is that correct? And number of the high oil pressure pump? Those numbers?
