Oil change?
TORGERSONDA
  • 2013 FORD F-150
  • 5,500 MILES
On the first oil change of our new truck, the dealer told us there was gas in the oil. They told us not to worry and just put some miles on it. In April, the check engine light came on and we took it in. Same thing. Gas in the oil. Gave us a free oil change and told us it was ok to drive. Is it safe to drive and not going to hurt the truck? The service dept. Says that it is an ongoing problem with this truck, but I just read that this could cause an explosion. Can I change the oil myself?
Friday, June 21st, 2013 AT 1:36 PM
DOCFIXIT
  • 18,828 POSTS
Yes it would be a good idea to change the oil because all engine have gas in the oil as part of the combustion process but if the injector has a problem it can dump too much gas which needs to be fixed before allowing the engine to run. Here is a step by step guide with diagrams and insticion below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Check out the diagram below to show you the location of the oil filter even though the filter has been removed show the location.
Ford Part Name
- Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil (US)
- Motorcraft SAE 5W-20 Full Synthetic Motor Oil (US)
- Motorcraft SAE 5W-20 Super Premium Motor Oil (Canada)
- Motorcraft SAE 5W-20 Synthetic Motor Oil (Canada)*
Ford Part Number
- XO-5W20-QSP (US)
- XO-5W20-QFS (US)
- CXO-5W20-LSP12 (Canada)
- CXO-5W20-LFS12 (Canada)
Ford Specification
- WSS-M2C945-A and API Certification Mark
* Note: Use of synthetic or synthetic blend motor oil is not mandatory. Engine oil need only meet the requirements of Ford specification WSS-M2C945-A and the API Certification mark.
Capacities
Engine Oil
With Filter .................... 7.3L (7.7 Qt)
Oil Filter AA5Z6714A $7.98
Friday, June 21st, 2013 AT 1:41 PM
ZDOGG
  • 2007 FORD F-150
  • V8
  • 4WD
  • 8,000 MILES
How much oil does this truck take
Monday, March 4th, 2019 AT 5:48 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Which engine? Usually around 6 qts plus or minus a half
GUSS16
  • 2007 FORD F-150
  • V8
  • 4WD
  • 25,000 MILES
F-150 I have a 2007 model with 25,000 miles and inadvertently not timely change oil change and worsen motor to sound, was diagnosed motor repair and complete repair and the vehicle in cold works fine but when it reaches normal temperature operating the engine begins to sound and becomes unstable, if it works well but is accelerating in stop or traffic lights, the problem becomes. If I try just disconnecting the VCT is the problem, change the VCT by new and ongoing problem, check all the parameters of the VCT and are perfect, the normal oil pressure is taken at the pump.
We attempted to reprogram the PCM (powertrain control module) and there is a higher version in the diagnostic equipment that allows it and do a forced rescheduling and made a road race in which normal operation, but we turned off and turned on the vehicle and return the problem.
I would like your views on this, if you know you may be going with that engine, I have seen in various internet forums user complaints about noise problems in the engine of the F-150.
Also if you know how we can reprogram a PCM
  • 108,355 POSTS
Can you describe the noise? Is it a knock, tick? When do you hear it the most?
GUSS16
The rattling noise is a strong and VCT are disconnected and stops ringing. Continued strong Tick
  • 108,355 POSTS
Is the engine holding good oil pressure?
GUSS16
Thank you for your interest, and I can confirm that the oil pressure is normal. Nevertheless commit him to erase the memory KAM and initials in the two tests It Works fine
  • 108,355 POSTS
I'm glad it is fixed. Let us know if you have other questions in the future.
