HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Electrical
Battery
Jump
2002 Ford F-150
APCFD
MEMBER
2002 FORD F-150
V8
4WD
AUTOMATIC
100,000 MILES
My truck had to be jump started and ran fine. After the truck set a while it was dead again. Is it the battery or alternator?
Monday, February 4th, 2008 AT 10:15 PM
98RANGERXLT
MECHANIC
You can take it to autozone and thaey will test both for you.
Monday, February 4th, 2008 AT 10:52 PM
Please
login
or
register
to post a reply.
Related Battery Jump Content
2002 Ford F-150 Truck Jumps/vibrates Coming Out Of...
When I Release The Clutch From A Dead Stop In 1st Or Reverse It Jumps/shudders Hard. When I Give More Gas At Higher Rpms Its Smoother. I Had...
Asked by
21rjr12
2002
FORD F-150
VIDEO
How to Jump Start a Battery
Instructional repair video
GUIDE
Battery Jump Start
A battery jump start is easy to do but can be hazardous if not performed correctly. This guide will show you the do's and don'ts to keep you safe, and get you back on the...
2001 Ford F150 Truck Has To Be Jump Started
I Recently Cleaned My Battery Terminals Using Napa Battery Terminal Cleaner. I Now Have To Jump Start My Truck Every Time I Attempt To...
Asked by
DJatcorner2
1 ANSWER
2001
FORD F-150
1976 Ford F-150 Electrical Demons.
Hi. I Have A '76 F-150 With The 4.9 300 6l. I Rebuilt It And Has 1000 Mi. Problem: Right After Rebuild, Under A Load, It Wants To Spuder...
Asked by
whyme1976
1976
FORD F-150
1995 Ford F150
My 1995 F-150 Has Dual Tanks, I Have Replaced The Fuel Filter And When I Drive For About Ten Minutes Its Starts Acting Funny. The Tach...
Asked by
britter32
1995
FORD F-150
2003 Ford F150 Intermittent Electrical Problem -...
I Have A 2003 Ford F-150 With V8. It Has An Electrical Problem That Started Very Intermittently And Now Has Become Constant. Here Is The...
Asked by
Larry Heinrich
1 ANSWER
2003
FORD F-150
VIEW MORE
Battery Jump Starter
How to Replace Battery
