No start, crankshaft position sensor?
JIGGSAWNELLIE
  • 1999 FORD F-150
  • 4.6L
  • V8
  • 255,000 MILES
So the truck has been blowing smoke out, a lot lately. As soon as I tried to start to the truck it clicks, doesn't turn over. Tried a jump, didn't do anything. All lights and A/C works to the fullest. I believe it's the crankshaft position sensor, but where is the crankshaft position sensor located on the pick-up truck listed above?
Thursday, April 23rd, 2020 AT 8:32 PM
Just to clarify, the engine clicks and does not turn over? Meaning it does not try to start? If that is the case, then the crankshaft sensor is not the issue. The crank sensor is used to locate the crank position when the engine is turning. It will not prevent the engine from trying to start.
Here is a guide that gets more into a click no start issue:
What color was the smoke when the engine was running? I would suggest starting with putting a wrench on the crank pulley bolt and making sure you can turn the engine over to ensure it is not seized.
Let me know if this is accurate and we can go from there. Thanks
Friday, April 24th, 2020 AT 7:52 AM
JIGGSAWNELLIE
When trying to start, the truck just makes a clicking noise, but doesn't turn over. The smoke was blue mostly then turns to grey. I will definitely do the test of seeing if the engine is seized.
Thank you so much for your help, I'll be in touch to let you know how I make out.
Friday, April 24th, 2020 AT 10:42 AM
Sounds great. That is good info. We may have two issues. If the motor is free and not locked up then we may just have a starter issue. Then we can tackle smoking issue separately. I will wait to hear back that the motor is not locked up and we can go from there. Thanks
Also, try spinning it over 360 degrees just to see if it make at least one complete revolution.
Saturday, April 25th, 2020 AT 8:52 AM
CMRICE7
  • 17 POSTS
  • 1999 FORD F-150
  • V8
  • 174,000 MILES
I have traced wiring from fuel pump to relay box its ok. I replaced ignition, no change. I then replaced camshaft positioning sensor no change, I then replaced crankshaft positioning sensor then got power to fuel pump and got fire. It ran for about 20 seconds and stopped. I then replaced crankshaft sensor again no change. No power to fuel pump and no fire to plugs. What do I do next?
Monday, August 3rd, 2020 AT 12:16 PM (Merged)
  • 108,262 POSTS
Switch the EEC relay with another relay with the same part number. See if that changes anything. The relay is under the hood in the relay block.
CMRICE7
  • 17 POSTS
I changed eec relay no change. I have tested all sensors and relays. I finally came up with only 0.34 volts to the coil packs. The red/ltgrn wire leads to pats module on the steering column. Could that be my problem/
  • 108,262 POSTS
It sounds like it. Now the problem is the wiring bad or another component. Have you checked the wiring for continunity?
CMRICE7
  • 17 POSTS
I have checked the wiring with no luck. Not sure if i'm checking the right wires or not. The module seems to be round and mounted to the steering column and has three wires coming out the plug and one is red/ltgrn but no continuity
BLUELIGHTNIN6
  • 16,542 POSTS
Pull up the RPM reading and crank the engine over. Hold accelerator to floor to shut off fuel to the engine. No reading find the crank sensor, inspect for damage, unplug electrical connector and clean it with electrcial contact cleaner spray and then plug the connector back into the sensor. Crank the engine while watching for RPM reading, again hold down the accelerator to prevent fuel flow to the engine. If you have RPM reading now sensor is ok, engine should run. The sensor by nature is very durable and should not fail. If you still do not see RPM you may have a internally damaged sensor or wiring problem.
RHOADETA
  • 11 POSTS
  • 1997 FORD F-150
  • 160,000 MILES
I have a rough idle its a 4.6 V8 4x4 auto changed plugs, wires, bench tested fuel injectors got a 0174 code a while ago but I have disconnected the battery so its not come back, I am not driving it. Also changed cam sensor and crankshaft sensor put maf and ecm in friends truck they work, I did a Vaccume test it reads between 5 and 10 inch hg with the beedle going back and forth between the two. At 2000 rpms its goes to 15 in hg and shakes back and forth not as bad at idle. I checked all vac lines and clean the maf iac and throttle body, Help lol Also the egr is deleted and the pcv is blocked of the truck was running fine like that for a year. I don't have a lot of cash left but if you help me when I do I will donate you have my word. Also did a fuel pressure test and changed inline fuel filter
  • 52,797 POSTS
Your vacuum gauge gave you the answer. You have a valve train issue. Do a compression test and you find the failed cylinder.
Shame you replaced all those parts. You should always start with basics.
CHUCK EVANS
  • 16 POSTS
  • 1997 FORD F-150
  • 4.2L
  • 6 CYL
  • 167,000 MILES
I checked the crank sensor with a multi meter and the ohms reading is around 34-35. Is this OK or is this the problem with it not getting any fire and starting? What should it be reading?
CARADIODOC
  • 33,752 POSTS
Don't know what normal is because that's a test we rarely do. This is a simple two-wire magnetic sensor so there's just a real long piece of wire wrapped around a magnet. Failures are typically going to consist of a broken wire, meaning infinite resistance, or corrosion between the connector terminals. It isn't likely one of these will short internally because the wire would have to get hot enough long enough to melt the insulation, and that's not going to happen.
If you want to know what a typical reading is, measure a new one or a used one in a salvage yard. The online service manuals don't even give a spec. Basically you're looking for something or nothing. The exact value isn't that important.
Also, you weren't clear in your reading. If that was 34 ohms, I could believe that. If that was 34kohms, that would be too high. Some ABS wheel speed sensor with a similar design can be in the area of 500 to 900 ohms. What's much more important is the voltage of the signal the sensor is putting out. If that is present but too low, look for something causing the air gap to be too big.
CHUCK EVANS
  • 16 POSTS
OK that helps! Thank you! I'll check the terminals and wiring!
WAYNECORBITT
  • 1995 FORD F-150
  • V8
  • 242,000 MILES
Where is the crankshaft position sensor located on my truck? I do not have any of the above listed items. Do I need to take it to a Ford shop to have them run a scan on it or can I unhook the battery to attempt to reset it?
A buddy said it might be that, I am just trying to figure out what is wrong with it and taking whatever advice I can get.
It was parked for a about two and half years and would only be driven every now and then because I was overseas. It started acting up after about two years and would lose power while my wife was driving and then quit running. If it would sit for a while she could start it back up and it would make it home. When I got home I changed out the fuel pump, coil, and had ignition module checked. Now it starts sometimes and other times it will not. If it does start it might run for a few minutes and then shut off. When it shuts off, it is as if someone turns off the key. It has no rhyme or reason as to when it will start or not.
Monday, August 3rd, 2020 AT 12:19 PM (Merged)
STEPHANIE ROSE WOODWARD
I have a 1992 Ford F150, 4.9 L, 300 straight six engine. Will crank over but not start. Have replaced the alternator, distributor cap and button, and still will not start. Thought it was crank sensor. Some told me it is located in alternator, some say it is not. Anyone have any opinions on this?
  • 31,938 POSTS
Location is at front of engine behind front pulley. Should take about 20 minutes to change out. This video show what to do its on a different car but you get the idea.
https://youtu.be/_xoGyRrHYbM
FORDNOTCHEVY
  • 1995 FORD F-150
  • 5.0L
  • V8
  • 166,488 MILES
Where is the crankshaft sensor and does a 1995 ford F1 50 have a sensor it's a 302 5.0 L automatic
  • 52,797 POSTS
Since your truck has a distributor it does not have a crank sensor.
DARLENEMAC63
  • 1995 FORD F-150
  • 5.8L
  • V8
  • 4WD
  • 135,000 MILES
Fuel filter has been changed fuel pump comes on truck will crank but not start could it be the crank sensor
