HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Climate Control
Heater
Not Working
1998 Ford F-150
MOJORIZEN101
MEMBER
1998 FORD F-150
6 CYL
2WD
AUTOMATIC
124,999 MILES
Heater blowing cold air. Controls seem to be working.
Wednesday, January 30th, 2008 AT 9:58 AM
BLACKOP555
MECHANIC
Run the vehicle untill it is warm then feel the heater core hoses right at the firewall and post back what you find.
Is one of them hot and one cold?
One hot and one warm?
Neither hot?
Both hot?
Both warm?
Tuesday, March 11th, 2008 AT 8:53 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
No Heat In The Interior Of The Pickup Truck Cab?
I Have Had The Heater Core, Radiator And Engine Flushed. Having Had A 195-degree Thermostat Installed Of Course With New Coolant. I...
Asked by
dmynard
1998
FORD F-150
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
1998 Ford F150
Heater Problem 1998 Ford F150 V8 Four Wheel Drive Automatic Yes The Heater Blows Out Cold Air And Not Heat I Would Send A Donation...
Asked by
anniehurst
1998
FORD F-150
Why My Heater Isn't Working?
I Have A 2002 Ford F150 4x4, 5.4 Triton Eng. I Have Change Thermostat But Still No Heat. If I Turn Fan And Heat Off It Will Build Pressure...
Asked by
noles
23 IMAGES
2002
FORD F-150
1994 Ford F150 Very Little Heat
3 Thermastates And Still Very Little Heat Temp Gauge Never Gose Past The (n) In Normal On The Gauge Heater Doors Open And Close Fine Ther...
Asked by
spider6
1994
FORD F-150
Heater Blew Nothing But Cold Air That Evening
I Replaced The Stat In My '97 Ford F150 - 4.6l. The Heater Worked Perfectly The Next Morning. It Blew Nothing But Cold Air That Evening...
Asked by
Mikie
1 ANSWER
FORD F-150
VIEW MORE
Heater Not Working
Blend Door Actuator Replacement
