Changing a timing gear
ROBBY STAATS
  • 1995 FORD F-150
  • 6 CYL
  • 4WD
  • MANUAL
  • 210,000 MILES
How to change a timing gear on a 1995 300 six cylinder Ford?
Sunday, December 12th, 2010 AT 7:43 PM
KHLOW2008
  • 41,815 POSTS
Here is the instructions and marks in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
Thursday, December 23rd, 2010 AT 2:43 PM
JAM32
  • 1994 FORD F-150
  • 6 CYL
  • MANUAL
  • 145,000 MILES
Replacing timing gears, how to press camshaft gear onto camshaft? Shaft moves back into block when you try to tap gear on. Is there a puller/pusher to get this gear on?
Wednesday, September 26th, 2018 AT 11:57 AM (Merged)
BLACKOP555
  • 10,371 POSTS
You are supposed to use a hydraulic press to do that. Take it in before you break the gear.
EFRAIN BARO
  • 2004 FORD F-150
V8 Automatic 100,000 miles.
What is the timing chain diagram for a Ford F-150 5.4 4x4, 2004?
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_668.jpg
