How much labor time and cost to replace the ignition switch switch?
Sunday, February 27th, 2011 AT 1:50 PM
ERNEST CLARK
MECHANIC
Here are diagrams to show you what will need to be done the parts should cost about $75.00 and labor about $140.00.
Cheers
Images (Click to make bigger)
SPONSORED LINKS
Monday, February 28th, 2011 AT 3:43 AM
DILL-11
MEMBER
Thank you I love this site.
Monday, February 28th, 2011 AT 1:26 PM
ERNEST CLARK
MECHANIC
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Monday, February 28th, 2011 AT 1:35 PM
RCONLEY1879
MEMBER
1 POST
1989 FORD F-150
Six cylinder four wheel drive manual.
How do I replace the ignition switch on this vehicle?
Tuesday, July 17th, 2018 AT 11:26 AM
(Merged)
BLACKOP555
MECHANIC
I have to verify, do you want to replace the tumbler, the part that the key goes in?
Or do you want to replace the switch, the thing that the tumbler activates?
People get the two mixed up.
SPONSORED LINKS
(Merged)
EFINREDNECK
MEMBER
Underneath column, large male side of wire cluster is plugged into switch mounted on side of column by two bolts. Unplug and remove two nuts. Carefully "shimmy" ignition switch from the long ignition rod that moves the switch that is actuated when you turn your key. Reinstall new switch same way. Careful not to let rod remove itself from key switch. Once yer heads underneath it is easily to visualize this explanation.
(Merged)
BLACKOP555
MECHANIC
Watch out, that rod is breakable, so as said carefully shimmy it, if you have to put some graphite spray on it to lube it up. Any little bit helps.
(Merged)
F150PROBLEMS
MEMBER
1 POST
1989 FORD F-150
6 CYL
4WD
MANUAL
The battery is fine, and I hooked another car to it and there was no juice going to my truck at all. I changed the ignition switch and nothing changed. Are there any main fuses that could cause this problem or would I need to buy a new steering column?
(Merged)
HMAC300
MECHANIC
Check items in picture either the relay on fender or the fusible link has burnt up. It should have 12 volts both sides on link.
