Brake line replacement?
LACY5404
  • 2001 FORD F-150
  • 5.4L
  • V8
  • 4WD
  • 100,000 MILES
How many hours to strip all brake lines out of truck including on callipers, replace all new oem stock mettal prebent, and flush whole system and bleed the system in a shop?
Sunday, December 8th, 2019 AT 2:38 PM
  • 108,320 POSTS
That's a tough one to call because condition of the vehicle and components play a big role in the work. Keep in mind, bleeders on wheel cylinders, calipers, the master cylinder, proportioning valve and so on can break leading to additional work. Here are videos to help you make your own line or replace the brake flex hose.
https://youtu.be/sO43p4ZFUiM
and
https://youtu.be/1Prs_coIuCg
The process is the same in most cases.
If the vehicle is in fair condition, I had to make the lines, and all bleeders and components being reused were okay, it would most likely take about 4 hours.
I hope that helps. There is no predetermined flat rate time for this type of job. Hope you understand.
Sunday, December 8th, 2019 AT 8:07 PM
LACY5404
This is a 100% full prebent brake line kit Which is meant to replace the original which is built on the truck frame before the body and everything else is put on the truck.
So it's pined around the frame, body, fuel tank, exhaust system, and transmission all in the way.
A shop told me that to pull everything out and replace everything to original specifications, in the same place is around 18-20 hours.
Monday, December 9th, 2019 AT 8:25 AM
  • 108,320 POSTS
If you want it routed the exact same way, it will take a lot of time.
Tuesday, December 10th, 2019 AT 5:04 PM
SAFDEMT
  • 1999 FORD F-150
  • V8
  • 4WD
  • 109,700 MILES
My metal brake lines are leaking but no one can tell me what size the lines are or if they are standard or metric thread. They are the metal ones that run the lenght of the frame and from master cltinder to abs pump. Do you have any ideas on size and thread?
Wednesday, March 10th, 2021 AT 1:27 PM (Merged)
MASTERTECHTIM
  • 4,749 POSTS
3/16 line and regular standard thread. The ones that actually connect to the abs unit use different ones connecting to it and vary in sizes but you can usually reuse the old fittings or you can splice into the line before the abs unit. Thats how I usually do it because the line is usually ok right at the abs unit
SZBOWLER
  • 1999 FORD F-150
  • 127,000 MILES
Brake line from the master cylinder to distribution manifold has a pin hole leak. Looks like the line has had a previous repair. Line as had a braided portion installed just above the leak. Is there a stainless steel replacement line available? What is the purpose of all bends towards the bottom of the line before it goes into the manifold, are the fittings at each end of the line the same?
CARADIODOC
  • 33,754 POSTS
The bends in the lines are to absorb vibration. The braided sections are because the body wobbles on the frame and the repeated bending caused the metal to work harden and crack. You can try getting a replacement line from the dealer but they don't do a good job of supporting vehicles more than about five years old. Auto parts stores are doing a pretty good job of supplying parts Ford doesn't want to. If they can't help, you can make a line by starting with a pre-manufactured steel line about two feet long, and use a tubing bender to make three loops about three inches in diameter. It will look like a giant spring when you're done.
You'll need to remove the old line first to see what ends they used. Ford used a line on the rear of the Taurus with a double flare on one end and an iso flare on the other. Double flares are easier to make so if you have to make a line with loops in it buy a line with two iso flares, cut one off and make the double flare for that end. The aftermarket parts suppliers are making the lines for the Taurus so there's a good chance they're making parts for your truck too.
If you do this right you won't have to bleed the system down at the wheels. Leave the lower fitting loose, then pump the brake pedal a few inches, (never more than half way to the floor), to run some brake fluid down the new line. Once no more air comes out tighten the fitting, then push the pedal again slowly, then let it release quickly. Any air bubbles will float back up, then they'll wash into the reservoir with the brake fluid that's rushing back.
BINGHAMK
  • 1990 FORD F-150
  • 6 CYL
  • 150,000 MILES
How do you replace the rear brake lines? They are very rusty and one has a leak in it.
  • 108,320 POSTS
Chances are you are not able to get a direct fit replacement. As a result, you have two choices. One is to purchase steel brake line sections at a parts store and just remove the old, and bend the new ones to fit. However, the pre-fab ones are already cut to different lengths. If you need a long section, they won't have one more than around 4 feet.
The other option is to purchase a spool of steel brake line, the fittings fot the ends, cut it to length, and then using a double flairing tool flair the ends that bolt to the car. It sounds harder than it is.
Let me know if you have other questions. NOTE: You will have to bleed the brakes when you finish.
ALIENBABE1971
  • 1984 FORD F-150
  • V8
  • 4WD
  • 10,000 MILES
Found a leak in my break line in rear of truck have no idea how to replace please help
  • 31,937 POSTS
Hi there,
Follow the line till you find a union, this will unscrew, locate both ends and remove as a single pipe, now this will involve a few clamps and possibly loosing other items to aide in its removal, only use a genuine pipe, and make sure that it is re fitted in the same position, the brakes will have to be re bleed to remove all air in the line, if in doubt about doing this, get a mechanic to do it for you.
Mark (mhpautos)
