2002 Ford Explorer keyless entry
FLHTPI386
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 78,000 MILES
I only had one remote for my vehicle, so I bought another one, I tried to program it but did not work and now my working remote quit working, the key pad did not work also, a mech tried to reprgram it but says I have a bad pcm, traced to a bad eeprom, if the pcm is bad wouldnt that affect the rest of the car, goes the keyless entry have its own module?
Do you
have the same problem?
Wednesday, May 19th, 2010 AT 10:06 PM
BLUELIGHTNIN6
  • EXPERT
The keyless entry system uses the Central Security Module, not the Powertrain Control Module.
Wednesday, May 19th, 2010 AT 10:11 PM
FLHTPI386
Would the bad EEprom prevent the tech from reprogramming the security system
Thursday, May 20th, 2010 AT 7:09 AM
BLUELIGHTNIN6
  • EXPERT
It is possible, the EEPROM is actually a computer chip inside of the main computer. The EEPROM is part of the receiving portion of the keyless entry, so if it fails then the transmitter's signals will not be read by the receiver (EEPROM).
Thursday, May 20th, 2010 AT 3:42 PM
Recommended Guides
