2000 Ford Explorer Fuel pump
2000 FORD EXPLORER
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
MATELSKI73
I have a 2000 ford explorer my started it to warm up it ran for about 5mins then died. I have drop the tank and checked the the fuel pump there is no power going to the sending unit. The relay is clicking and I have check the reset switch on the passenger side that was not tripped either. Can you help me out? There is no power at the connector by the rear wheel for the sending unit.
Jan 20, 2008 at 6:57 PM
FLEXY5
  • CAR REPAIR CONTRIBUTOR
  • 512 POSTS
check the plug at the inertia switch (reset switch). It may have come loose enough to not make a good connection. Check for power going into the switch and coming out of hte switch. Let me know what you find and I'll help you from there.
Jan 20, 2008 at 10:19 PM
