1998 Ford Escort HELP
KACYMARC
  • 1998 FORD ESCORT
Engine Cooling problem
1998 Ford Escort 4 cyl Two Wheel Drive Automatic
Changed the water pump, thermostat, radiator and timing belt. Not it will not start. Its trying to turn over but it wont start. Any solutions?
Sunday, July 25th, 2010 AT 2:46 PM
Do below to determine whether it's fuel or spark:
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, July 26th, 2010 AT 12:00 AM
