My Heater is not working
EZRIDER
  • 2004 FORD CROWN VICTORIA
  • V8
  • 72,000 MILES
The heater on vehicle is not working?
Sunday, November 15th, 2009 AT 6:00 PM
WAY2OLD
  • 195 POSTS
A little more information is needed. Where does the temperature gauge stay? this guide can help us fix it
https://www.2carpros.com/articles/car-heater-not-working
Monday, November 16th, 2009 AT 5:51 PM
EZRIDER
Yes the radiator is working, radiator cap is ok, the radiator is flowing, the coolant is ok too and the temperature is where it should be, normal. The "door", I'm not too sure about that.
Monday, November 16th, 2009 AT 6:44 PM
WAY2OLD
  • 195 POSTS
Park the car in a quiet location. Shut all doors, turn the key on, wait for all dinging to stop. Then turn the heat selector from cold to hot and see if you can hear a litthe motor running followed by a dull thud. Then try it from hot to cold. If it does not make a noise, the actuator is bad. If it makes a noise and no "thud", the door is broken or the gears are stripped in actuator.
Tuesday, November 17th, 2009 AT 6:31 AM
SKRIMSKI
  • 2002 FORD CROWN VICTORIA
Heater problem
2002 Ford Crown Victoria V8 Two Wheel Drive Automatic
I Heater and AC will not come on. Checked and replaced relay in engine compartment, all fuses checked, blower motor works when jumped straight from 12 volt system. Lights work in panel shows automatic with set temperature and fan light, but no blower motor or condensor movement.
Wednesday, January 13th, 2021 AT 12:27 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
Since you have an auto temp control system, you likely have a bad Blower Speed Control Module. They fail quite often. It's located in the blower housing, right near the blower motor.
2CP-ARCHIVES
  • 4,542 POSTS
  • 2001 FORD CROWN VICTORIA
  • 98,000 MILES
When I turn the heater on it doesnt warm up. It continues to blow cold air. I was wondering if there is a quick fix I could possibly try cause I dont have time to take it to the shop right now
BLAZE45
  • 380 POSTS
It is probably 1 of 2 things. Your blend door is stick open/closed or your valve that lets warm water into the heater core is broke. There should be 2 lines that go into the heater core into the firewall of the car. The valve should be right in that area or just on the other side of the firewall. You can manually check the valve and see if it is causing the issue. Your heater core could be clogged as well though.
Good luck.
TAXIMAN805
  • 430,000 MILES
I have a 2001 Ford Crown Victoria with climate control, the heater stopped working but the air conditioner still works, what is wrong with the heater or how can I fix it? If the air conditioner is NOT on it gets hot in the car, as if the heat was on but it’s not on. The air conditioner works just fine but no heat unless you turn OF the climate control. Can you help me?
FIXITMR
  • 9,990 POSTS
4hundred thirty thousand miles? You mean heat dont blow?
TAXIMAN805
Yes the heat does not blow but the ac blows just fine
TAXIMAN805
Yes and it dose have 4 hundred and 30tousand miles Original engine
  • 108,192 POSTS
Check the blend door if it feels like heat is on all the time. That is a lot of miles. Does it still run well for you?
FIXITMR
  • 9,990 POSTS
If it's getting heat but not blowing check your underhood wiring on firewall pass side to fan / resistor/ speed control. If nuthin looks burnt melted try unplugging and re-plugging. Could also be bad speed control or resistor.
FAYEFAYE1
  • 1999 FORD CROWN VICTORIA
  • 4 CYL
  • 111,111 MILES
Heater is blowing cold air changed the thermostat but didn['t help
  • 31,938 POSTS
First thing to check is that both heater hoses are hot to touch with the engine at normal operating temp, check that first and let me know what you find.
KSTRINGER
  • V8
  • 160,000 MILES
Car has a sound of coolant inside passenger side under dash. Coolant does not leak on floor. Heater blows hot, extremely hot. Air conditioner also blows extremely hot. AC freon level is good.
  • 108,192 POSTS
What you hear is coolant entering the heater core. It can be caused by low coolant or an air pocket in the system that needs bleed.
AMY RUSHING-ADAMS
  • 1998 FORD CROWN VICTORIA
  • V8
  • MANUAL
  • 170,000 MILES
Heater blows cold air through all vents.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
First thing to do is check your engine coolant level when the engine is cold so you do not burn yourself, unless of course you have an overflow jug that you can just check, because if the engine coolant level is low, the heater core will not have hot coolant flowing through it, it will have just lukewarm air which might just feel cool by the time the blower motor blows air across the heater core.
Wednesday, January 13th, 2021 AT 12:28 PM (Merged)
JUNE BARKER
  • 1993 FORD CROWN VICTORIA
  • V8
  • 132,789 MILES
The blower works because it blows cold air but no warm air. The slider from blue which is cold to red which is warm makes no noise when moving like not connected. I am freezing.
