HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aerostar
Climate Control
Heater
Not Working
1994 Ford Aerostar no heat
HARTCC
MEMBER
1994 FORD AEROSTAR
Heater problem
1994 Ford Aerostar 6 cyl Wheel Drive Type unknown Automatic 112000 miles
The heater is not blowing warm air. Could this be a vacuum operated switch? If so, where is the switch located?
Sunday, January 13th, 2008 AT 3:20 PM
MECHANIC
For a start check the coolant level and find the thermostat and replace it -cheap fix and go from there.
Sunday, January 13th, 2008 AT 3:46 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
1994 Ford Aerostar Heat Stop Working
Heater Problem 1994 Ford Aerostar 6 Cyl Two Wheel Drive Automatic My Heat All Of A Sudden Stop Working. It Went Out Came Back On And...
Asked by
Dubb
1 ANSWER
1994
FORD AEROSTAR
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
1994 Ford Aerostar No Heat In Fornt Of Car
My Car Has Duel Heating Front & Rear. The Rear Works Fine, But The Front Does Not.
Asked by
glambert
1 ANSWER
1994
FORD AEROSTAR
1989 Ford Aerostar Heater Blows Cold
Why Doesn't My Heat Work? Replaced The Thermostat, Reconnected The Hose From The Blower.
Asked by
johbey
1989
FORD AEROSTAR
1993 Ford Aerostar Heater Blowing Luke Warm Heat
I Replaced My Thermastat, Heater Core & Flushed The Radiator And Ever Since I Did That It Blows Luke Warm Heat And Stops Blowing On...
Asked by
Threhor2002
1993
FORD AEROSTAR
1987 Ford Aerostar Very Little Heat
I Just Put A New A Cooling System Had A Few Leaks.I Did Not Have Real Good Before And It's About The Same Now. Both Hoses Are Hot. Is There...
Asked by
Dukedog
1 ANSWER
1987
FORD AEROSTAR
VIEW MORE
Heater Not Working
Blend Door Actuator Replacement
How to Replace Damper Door Switch
