Firing order?
MAXIES101
  • 2001 MAZDA 323
  • 1.8L
  • 4 CYL
  • FWD
  • MANUAL
  • 217,000 MILES
Hi just wondering what is the firing order of mazda 323 astina 2001 model ( I think this is a 6th generation-/correct me if im wrong.
Need an answer, help please.
And if its 1342 - what is the valve clearances for intakes and exhaust valves?
Thank you in advance.
I would really appreciate your help
Regards,
Maxi
Friday, December 6th, 2013 AT 2:30 PM
HMAC300
  • 48,601 POSTS
0010-.0026 (.025-.066)
Maximum.0071 (.180)
metric in parenthesis. Firing order is as you have it listed. Check out the diagrams (Below). Please let us know what happens.
Saturday, December 7th, 2013 AT 8:23 AM
MAXIES101
Thank you!
But can you provide me the definite measurement? In mm.
Saturday, December 7th, 2013 AT 1:49 PM
HMAC300
  • 48,601 POSTS
Read above metric or mm is in parenthesis
Saturday, December 7th, 2013 AT 5:19 PM
CARSAW
  • 1989 MAZDA 323
  • 4 CYL
  • MANUAL
  • 15,500 MILES
What order do the spark cables go in around the distributor cap to the cylinders?
Thursday, December 17th, 2020 AT 9:56 AM (Merged)
Here is the firing order for your car.
https://www.2carpros.com/forum/automotive_pictures/12900_fo_112.jpg
Cheers
LESLEY MEYER
  • 1989 MAZDA 323
  • 1.3L
  • 4 CYL
  • MANUAL
  • 288,520 MILES
I need a picture of how the firing order from engine to distributor. Is it clock wise or anti clock wise? Is for midge 1300. 323.
SCGRANTURISMO
  • 4,897 POSTS
I have included the information that you requested in the diagrams down below. I hope that this helps. Check out the diagrams (Below). Please let us know what happens.
Thanks,
Alex
2CarPros
SALAAM MOHAMED
  • 2000 MAZDA 323
  • 1.3L
  • 4 CYL
  • MANUAL
  • 277,000 MILES
I connected the spark plug cables in the wrong order and now the car won't start.
Wednesday, January 27th, 2021 AT 11:21 AM (Merged)
  • 108,355 POSTS
This engine wasn't offered in the US. However, I believe the attached pic shows the correct routing. Try that and let me know if it works.
