1999 Fiat Uno Starting Problem
SURECOOL73
  • 1999 FIAT UNO
Electrical problem
1999 Fiat Uno 4 cyl Manual 75038 miles
This is one great Car I ever had. I liked driving it because it gives a lot of mileage and power compared to higher models. The Problem is with the Fuse. Often the car fails to start. I changed the battery because I thought it was the problem. But even after that the car failed to start. My mechanic showed me how to change the starting fuse. Problem is every 2 days I have to change the fuse. What is causing this problem because my mechanic is virtually clue less. I lost a lot of my money in this. With the recession it is very tough to make money too.
Do you
have the same problem?
Thursday, April 23rd, 2009 AT 1:23 AM
DAVE H
Check for wiring short on starter
Friday, February 26th, 2010 AT 7:27 AM
Recommended Guides
