Code p0401, change EGR valve, cleaned tube to intake. Code still return in about five miles.
Thursday, November 2nd, 2017 AT 6:19 AM
MECHANIC
Often times, there is a carbon build up in the intake where the EGR is mounted. Make sure that area is clean.
Thursday, November 2nd, 2017 AT 5:38 PM
SATURNTECH9
MECHANIC
Just to add to this one have you removed the her valve and started it yet?That will tell you a lot the engine should rev up considerably and you should hear a large exhaust leak if both ports are clear. Try doing that and let me know if the engine just idles normal and you hear a large exhaust leak.
Friday, November 3rd, 2017 AT 7:45 PM
SATURNTECH9
MECHANIC
The egr valve yet and started it I ment my phone likes to change the words I type on me.
