Camshaft timing
NNOSEWORTHY
  • 1997 EAGLE VISION
  • 3.5L
  • 6 CYL
  • 108,000 MILES
The timing belt tension-er fell out of my vehicle listed above ESI model, 3.5L 24 valve overhead cams. The car shut down while I was driving. I need to know how to be sure my cam shafts and valves are positioned properly to reinstall the new tension-er and belt. When I took it apart the camshaft sprocket passenger side mark was right on, but the driver side camshaft sprocket was of to the left of the case marks about two to three inches, so then I lined both cam sprockets on the timing marks on the housing, but I am not sure if the valves are in their proper position. How can I be sure without doing any damage to the valves before installing the belt again? Please and thanks.
Tuesday, October 2nd, 2018 AT 9:04 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,081 POSTS
Here is a guide that will help you see how the tensioner goes and the timing belt marks as well:
https://www.2carpros.com/diagrams/eagle/talon/1997
Cheers, Ken
Wednesday, October 3rd, 2018 AT 3:03 PM
REBELCHARLIE
  • 1997 EAGLE VISION
Engine Mechanical problem
1997 Eagle Vision 6 cyl Two Wheel Drive Automatic
engine jumped time. How do you retime the engine. Engine is a 3.25 24 valve over head cam.
Thursday, October 4th, 2018 AT 10:39 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Timing is controlled by the PCM , its non adjustable.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2609.jpg
REBELCHARLIE
  • 1997 EAGLE VISION
what is the timing sequence for a 3.25 24 valve 1997 eagle vision?
https://www.2carpros.com/forum/automotive_pictures/12900_fo_143.jpg
SPEEDEE15
  • 1994 EAGLE VISION
  • 6 CYL
  • FWD
  • 219,000 MILES
I am doing a timing belt and I am not sure about the timing marks. I is a dual overhead cam and I see two marks on each cam. I am not sure what marks are the ones to use. If you could help I would really appreciate it.
Which engine do you have 3.3 or 3.5?
SPEEDEE15
See below
3.5L
https://www.2carpros.com/forum/automotive_pictures/12900_timing_belt_vision_1.jpg
JOSH_TIFF.KX500
  • 1993 EAGLE VISION
  • 6 CYL
  • FWD
  • 150,988 MILES
Is the 3.5 liter v6 a interference motor
SERVICE WRITER
  • 9,123 POSTS
I would say "no".
https://www.2carpros.com/forum/automotive_pictures/30961_vis_1.jpg
