Window not working
MIGHTTUSS
  • 2007 HONDA ELEMENT
  • 4.2L
  • 4 CYL
  • 4WD
  • 80,000 MILES
I have found some on Amazon but the number do not match what is on the motor of the regulator I took out of our honda. The number on the motor is 609280. My question is where can I order the right 2007 honda element window regulator?
Saturday, September 6th, 2014 AT 9:29 PM
WRENCHTECH
  • 20,758 POSTS
Amazon has this part which is a common problem with these cars. Here is a video and the part below for $123.00 I think the dealer gets about $650.00 for the job
https://youtu.be/Wp7Ak9IGs4o
https://www.amazon.com/gp/product/B005VNR0W2/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B005VNR0W2&linkId=92f8e75566eebe234f27c8b44e510091
. Please let us know if you need anything else to get the problem fixed.
Sunday, September 7th, 2014 AT 5:29 AM
PTRIE
  • 2004 HONDA ELEMENT
  • 6 CYL
  • 80,000 MILES
After replacing the motor assembly for the power window, auto close allows the window to go all the way up (closed) but then comes back down to about 1/4 open position. Can you help? What did I do wrong? Thanks
Monday, April 1st, 2019 AT 2:57 PM (Merged)
CAR-MAN145
  • 321 POSTS
Try rolling up the window and holding the button up for 10 seconds to reprogram the windows
ELZASH
  • 4 CYL
  • 80,000 MILES
My power window fell off track. We got the panels off and down to the lift mechanism but we don't understand how it works.
KHLOW2008
  • 41,814 POSTS
Hi elzash,
Carefully lower the glass (A) until you can see the bolts, then remove them. Carefully pull the glass out through the window slot if you want to remove the glass. Take care not to drop the glass inside the door.
If you wish to adjust, the glass can be adjusted after removal of the bolts.
https://www.2carpros.com/forum/automotive_pictures/192750_DoorGlass04Element01_1.jpg
BAILEY WITT
  • 2.3L
  • 4 CYL
  • 4WD
  • 120,000 MILES
I know where I can get the regulator part, however I do not know the correct tools that I will need to complete the repair myself? Is there a list of tools that should get the job done? I have heard that you mainly use a screwdriver and torque wrenches, is that correct?
SATURNTECH9
  • 30,869 POSTS
Usually a screwdriver and a 10mm socket with a ratchet. If you have a socket set better yet.
SETBLDR
  • 160,000 MILES
What do you do if your window is stuck in the up position before you start replacing the regulator?
HMAC300
  • 48,601 POSTS
First check for power to motor from switches and then to motor. If motor is getting power, but does nott work it may be a bad motor.
DCANNELL
  • 2.4L
  • 4 CYL
  • AWD
  • MANUAL
  • 184,000 MILES
This has been an on-going issue, can't get the electric window to go up. I don't think I've even seen it not go down. Usually I've been able to get it to go up by fiddling with both the drivers & passengers side switches on the drivers side. However this time it's down and not moving. I've had both switches (drivers & passengers) out and poured some alcohol in them while activating the switches to no avail. I've been able to locate a junkyard switch for the drivers side for $35-40 but no response yet on the passengers side switch. I think what I could really use is a schematic so I could at least get the window rolled up unless of course it's a motor issue. From reading about people with apparently similar problems I do NOT hear the motor running so I'm assuming (yes indeed, I do know how it's spelled 8-) that the issue is not the cable tearing out of the wind-up sheave. Thanks, Dave Cannell
Monday, April 1st, 2019 AT 2:58 PM (Merged)
HMAC300
  • 48,601 POSTS
Slam the door if the window goes up the motor is bad. Check items in pic it may be switch too on drivers side as that powers pass side
AZVALBRO
  • 2003 HONDA ELEMENT
My power window on the passenger side window will not go up or down. When you hit the switch on the door you can hear the motor go but the window does not move. I got the door panel off and I can see the two springs have come loose but im not sure where they connect. Can you please help me
HONDA TECH 1818
  • 536 POSTS
The passenger window regulator is broken, you need to replace the regulator. Here is a video that shows you how.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2006 HONDA ELEMENT
  • 87,000 MILES
Is there an Element with roll down rear windows?
Monday, April 1st, 2019 AT 2:59 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,288 POSTS
Unfortunately this car does not have roll down rear windows.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
