1998 Dodge Truck Engine turns over, won't start
YAMATOK
  • 1998 DODGE TRUCK
  • V8
  • 4WD
  • 171,000 MILES
My 1998 dodge ram 2500 will not start. I believe my asd my be activated. I have checked all relays and fuses all are good. I have 12volts at #30 slot on the asd relay, and when jumpered to the 87 slot I have no voltage at the coil or injectors. I do not hear the fuel pump coming on either. I do have an active ground, at the asd relay. On the fuel relay, when I jumper that, I can hear the pump coming on. Any Ideas?
Thursday, March 5th, 2009 AT 6:29 PM
HENDERSONMD
I have been working on a 94 Dodge truck that would not start. If the truck cranks over check the voltage at the plug for the crankshaft position sensor first, it shoud be 8v, if the voltage is correct the first place to look is the crankshaft position sensor, they are notorious for going bad. I replaced the one on the 94 I am working on and it started right up.
Friday, March 6th, 2009 AT 3:32 PM
