Blower motor speed?
CLAIRE 54
  • 2004 DODGE STRATUS
  • 4 CYL
  • 56,000 MILES
When I turn on my heater to settings 1, 2 or 3 no heat comes out - but when I turn on 4 I get heat - what is causing this problem
Wednesday, November 19th, 2008 AT 10:37 PM
ZACKMAN
  • 4,202 POSTS
Bad heater resistor. Get a new one from your friendly Dodge dealer, look behind your glove compartment and follow this instruction below this guide can help as well
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Thursday, November 20th, 2008 AT 7:52 PM
MOGLIESBALOO
  • 2000 DODGE STRATUS
Please help me the heater will not work on levels 1 2 or 3 on ly works on 4 what do I have to do
Tuesday, October 27th, 2020 AT 10:11 AM (Merged)
The fix here is replace the blower motor resistor
DENISES
  • 1998 DODGE STRATUS
  • 6 CYL
  • 134,000 MILES
As I was driving to work today. The heater was on, I turned it off as it was getting warm in the car. I turned it back on a little later and it wouldn't work on any speed except high. I checked the fuse in the inside fuse panel and thought of checking the a/c relay under the hood but if it was burnt out would I still get heat on high speed? I'm not sure what to check now, can you help? Please!
Thanks very much for any info you can provide.
2CARPRO JACK
  • 11,533 POSTS
There is a blower motor resistor on the right side of car behind dash on HVAC plenum. Follow the wires from the blower motor back to the resistor. See if it gets power to it at all settings, get back with what you find
DOUG STRICKLAND
  • 2003 DODGE STRATUS
  • 4 CYL
  • FWD
  • 51,000 MILES
The fan will run on high, but will not work on the other 3 fan control settings. What can I do.
Tuesday, October 27th, 2020 AT 10:37 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Hi Most likely the blower resistor that lowers voltage to motor for slower speeds. Located in air plenum just left of motor has plug and couple of screws. see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_596.jpg
Hope this helps
Thanks for donate
SDESKAR
  • 2002 DODGE STRATUS
My fan blower operates only on highest setting(4) and will not work on 1, 2, and 3 settings can you help?
EDUGGER
  • 23 POSTS
Hey, most likley a resistor, this is located by the blower housing usually mounted on the firewall on the passenger side, another thing it could be is the switch, highly unlikely though, the switch is testable if you have a volt meter, you can pick up the resistor for 8-10 dollars
LISA2762
  • 2001 DODGE STRATUS
Heater problem
2001 Dodge Stratus Front Wheel Drive Automatic 109k miles
the 2 lowest settings on the blower (heater/air) do not work and the cruise control stopped working as well.
BLUELIGHTNIN6
  • 16,542 POSTS
Check blower motor relay, if OK test blower motor resistor.
For the cruise control, check fuse. Are brake lights still working? Is the CC indicator coming on in dash when pushing the CC switch ON?
