Battery location
VBARKLEY
  • 2004 DODGE STRATUS
  • 6 CYL
  • 20,000 MILES
Where do I bolt down the negative battery ground on a 2004 dodge stratus. The cable comes from the battery to a junction where another cable runs towards the tranny. Where do I ground it?
Friday, January 21st, 2011 AT 2:15 AM
CARADIODOC
  • 33,752 POSTS
The negative cable runs up to the front top of the left strut tower. It bolts on right between the two front strut mounting bolts. This guide will help walk you through the steps with diagrams below for your car.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Friday, January 21st, 2011 AT 2:58 AM
BACAT68
  • 6 CYL
  • 50,000 MILES
We cannot find the battery under the hood or in the trunk.
Saturday, November 23rd, 2019 AT 3:39 PM (Merged)
https://www.2carpros.com/forum/automotive_pictures/12900_b_5.jpg
ANDREWBECKER
Step#1 Disconnect negative battery cable next to engine using 15mm wrenches then lightly loosen up lug nuts on drivers side front tire. Step#2 Jack up front drivers side of the car then place jack stands underneath. Make sure car is secure before proceeding. Step#3 Remove front drivers side tire. Step#4 Remove front drivers side plastic fender well with various screwdrivers and plastic rivet popper tool. Step#5 Remove battery hold down with I think 13mm or 14mm socket or wrench Step#6 Remove battery cables with 5/16 socket or wrench. Step#7 Picture doesn't show it but there's another battery hold down with a bolt that goes through the hold down horizontally directly into the car frame. I think it's 14mm or 15mm
SMELLYA
  • 6 CYL
  • AWD
  • 73,000 MILES
Where is the Battery in a stratus?
OBXAUTOMEDIC
  • 3,711 POSTS
Look in front of the drivers wheel.
https://www.2carpros.com/forum/automotive_pictures/188069_dodgebatlocation_2.jpg
HILLBILLY650
  • 4 CYL
  • FWD
  • 57,000 MILES
Cannot locate, how do I get to it?
Sedan or Coupe
2004 Dodge Stratus Sedan L4-2.4L
Battery Location
https://www.2carpros.com/forum/automotive_pictures/12900_bat1_1.jpg
2004 Dodge Stratus Coupe L4-2.4L VIN G
Locations
Views A - K
https://www.2carpros.com/forum/automotive_pictures/12900_bat2_1.jpg
Views B
https://www.2carpros.com/forum/automotive_pictures/12900_bat3_1.gif
NICHOLAS82555
  • 2003 DODGE STRATUS
Electrical problem
2003 Dodge Stratus 4 cyl Two Wheel Drive Automatic
I need to jump start car. I found the Negative side battery cable but I can't locate the Positive side to hook up the jumper cable to.
NICHOLAS82555
This is a new car and new configuration. I've got to trade this monkey in. But I found both lead ends. The Negative sits in plain view on the right side engine compartment at top labeled Negative Jumpstart and the Positive is just south of it covered by a red cap on the Fuse Box. Geezzzzzz
SAMPSON
  • 6 CYL
  • 121,000 MILES
Where is the battery located on the dodge stratus
The battery is in the driver's front fender in front of the wheel. It is directly below where the (+) and (-) terminals are in your engine bay. You will need to remove the wheel and the wheel cover to access it.
LEGITIMATE007
  • 5,121 POSTS
If it is not under the hood on the right hand side, it will be in the trunk in its own protective compartment.
Saturday, November 23rd, 2019 AT 3:40 PM (Merged)
CJRLIVE2006
  • 2000 DODGE STRATUS
  • 6 CYL
  • 138,500 MILES
Im trying to change my battery but I can not see were my battery is. How do I change my battery in a v6 engine 2000 dodge statis?
CARADIODOC
  • 33,752 POSTS
Turn the wheels to the right. The battery sits in front of the left front tire. Remove the plastic shield to get to it.
Caradiodoc
WARLORDSLEEZY
  • 2002 DODGE STRATUS
Electrical problem
2002 Dodge Stratus Front Wheel Drive Automatic
Where is my cars battery?
Saturday, November 23rd, 2019 AT 3:41 PM (Merged)
The battery is located by the driver's front wheel. You have to turn the wheel all the way in to access the panel to remove the battery.
WARLORDSLEEZY
Thanks! Now I can get to work on it. :)
