Won't come out of park
JOAUNEE
  • 2005 DODGE STRATUS
  • 4 CYL
  • FWD
  • 69,400 MILES
I parked my stratus in the driveway today and tonight it won't come out of park. It's like the button on the gear shift won't release so you can pull back on the shifter?
Thursday, December 3rd, 2009 AT 7:53 PM
You have a problem with the shift interlock control system either the cable broke are the adjustment is off here are instructions in the diagrams below to help you fix the problem. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Friday, December 4th, 2009 AT 6:05 AM
OIDAVEY
  • 0 POST
Thank you for this post I had this problem and had to get a new interlock cable cost me $78.00 all fixed! I love this site.
Friday, August 16th, 2019 AT 2:00 PM
ANGELALANDERS1
  • 6 CYL
  • FWD
  • 60,000 MILES
2005 Stratus. When I try to start car, the gear shift will not come out of PARK. We have tried to get it towed, but when we try to put it in neutral, it will not come out of PARK. Help.
Angela
Friday, August 16th, 2019 AT 2:01 PM (Merged)
  • 108,289 POSTS
Are the brake lights working?
ANGELALANDERS1
Yes, the break lights are working.
  • 108,289 POSTS
Then eithere there is a wiring issue to the park lock actuator or the actuator itself is bad. The reason I asked about the brakes is because the brake light swith sends the power to the actuator to release when the brake lights come on.
You will need to have the actuator checked.
RANDYA60
  • 2003 DODGE STRATUS
  • 6 CYL
  • FWD
  • 80,000 MILES
Wont Shift outta park very ez, Is the Safety switch going out?
You could be having problems with the shift interlock system its not a DIY fix unless a you're a professional electrician
MILF4EVA74
  • 1996 DODGE STRATUS
  • 4 CYL
  • FWD
  • 127,000 MILES
If a ignition shifter/park interlock were faulty would it cause my car to not shift out of park?
2CARPRO JACK
  • 11,533 POSTS
Sure can. Check all your fuses first. Might also be the brake light switch, it operates the lock-out solenoid for the shifter, so check your brake lights first. If you care to diagnose this further, get a test light and PM me
