Spark plug gap
ADRIANHE
  • 2002 DODGE NEON
  • 4 CYL
  • FWD
  • MANUAL
  • 156,000 MILES
Hi, What is the correct spark plug gap for my car. The recommended plug is a NGK BKR6E (6962).
Thanks
Monday, December 8th, 2008 AT 9:04 AM
MORTICAR
  • 46 POSTS
Under the hood is a sticker with engine information on it one of those pieces of info is the spark plug gap reccomended by the manufaturer. You can also look in the tune up section of your auto manual for that info as well. Hope this helps MORT
Monday, December 8th, 2008 AT 12:46 PM
ADRIANHE
  • 6 POSTS
Thanks, found it. It must be 0.82mm
Monday, December 8th, 2008 AT 12:54 PM
MORTICAR
  • 46 POSTS
No problem glad i could help! It's important that you find out what gap is for your engine... good job checking that, most people don't bother
Here's a guide on tune-up's, it will show you everything you need to cover
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Monday, December 8th, 2008 AT 1:12 PM
JEFFYOUNG1
  • 2003 DODGE NEON
  • 4 CYL
  • 150,000 MILES
2003 Dodge Neon 2.0 SXT - One spark plug has popped out 3 times in last 6 months (twice in last week). I'm presuming the threads are damaged. Can a Helicoil kit work or do I need a new Head? Is it safe to drive while I figure out how to fix as long as I tighten the plug before driving?
Saturday, December 1st, 2018 AT 8:17 AM (Merged)
WRENCHTECH
  • 20,757 POSTS
Yes, a heli-coil will work but it has to be installed correctly by someone with experience because a mistake will ruin the head or possibly even the block. They make a special installation kit for the Ford V8s that will probably work on that one too.
THEBAMER10
  • 2001 DODGE NEON
  • 4 CYL
  • 119,111 MILES
My daughters car smokes for a minute after starting (white) and I removed the spark plugs, and there was oil on the outside of 3 of the four. I am asking what is causing this?
BMRFIXIT
  • 19,053 POSTS
Valve cover gasket o rings
i would replace them
RLPEZ2003
  • 1998 DODGE NEON
  • 4 CYL
  • MANUAL
  • 119,000 MILES
I have a 98 Dodge Neon Dual Over Head Cam and mistakenly put spark plugs for a Single Over Head Cam in it before finding out that the specs are different. My car is running fine and does not appear to be misfiring. If I leave them in will it damage my car or are the spec differences not that significant?
  • 108,192 POSTS
You really should replace them with the correct ones. Spark plugs are designed to perform at different temps, and they have different lengths. I have actually seen a hole burnt in a piston as a result of too hot of plug. THerefore, replace them with what should be in the engine.
