1997 Dodge Intrepid lack of heat
DODGE97INTREPID
  • 1997 DODGE INTREPID
  • 6 CYL
  • FWD
  • 121,000 MILES
The heat from heater take a while to get warm and when driving and fan on high it seems to blow kinda cool air but after it has been driven a while and you stop and let it idle after a few minutes it will start to blow hotter air and when you start driving the air cools down but if I keep fan control on a lower speed it seems to heat inside of car better. Thermostat has been changed and heater core backflushed car seems to run at normal temp. I'm kinda lost cause normaly you have to turn heat down after a few to be comfortable and not roast you out.
Thursday, January 22nd, 2009 AT 11:24 PM
Could be a problem with the air mix/blend/mode doors, vacuum and actuators, to include the HVAC control module
Friday, January 23rd, 2009 AT 3:31 AM
DODGE97INTREPID
Where is these located and how can I check to see where problem is I can't find anything in my book on these area's
Friday, January 23rd, 2009 AT 7:17 AM
Its all behind the instrument panel and can be complicated I recommend you take it to a professional to perform it
Friday, January 23rd, 2009 AT 12:26 PM
Related General Content
