THERMOSTAT
GDEW
  • 2003 DODGE INTREPID
Where is this location on my car so I can replace it
Saturday, March 21st, 2009 AT 9:41 AM
  • 108,319 POSTS
Hi:
If you follow the upper radiator hose back to the engine, it will end at the thermostat housing. The t-stat is under the housing.
Thursday, April 2nd, 2009 AT 9:22 AM
W.FREEMAN78
  • 2002 DODGE INTREPID
  • 111,000 MILES
3.5 engine where is thermostat located and how to replace?
Sunday, January 5th, 2020 AT 1:25 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
ENGINE COOLANT THERMOSTAT
REMOVAL
WARNING: DO NOT REMOVE PRESSURE CAP WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR.
1. Disconnect negative cable from remote jumper terminal.
2. Drain cooling system.
3. Raise vehicle on hoist.
4. Disconnect electrical connectors from engine oil and power steering pressure switches.
5. Disconnect radiator and heater hoses from thermostat housing.
6. Remove thermostat housing bolts.
7. Remove housing, thermostat, and gasket.
INSTALLATION
1. Clean gasket sealing surfaces.
2. Install thermostat and gasket into thermostat housing. For ease of installation, install bolts in housing for thermostat and gasket retention.
3. Install thermostat and housing to cylinder block. Tighten bolts to 12 Nm (105 in. Lbs.).
4. Connect heater and radiator hoses and install hose clamps.
5. Connect electrical connectors to engine oil and power steering pressure switches.
6. Lower vehicle and connect negative cable to remote jumper terminal.
7. Refill cooling system.
8. Connect negative cable to remote jumper terminal.
MSLCWILLIAMS
  • 6 CYL
  • FWD
  • 65,000 MILES
What is the location of the thermostat on the engine. Is there a site availabel to see a picture of it and how the area around it looks?
BMRFIXIT
  • 19,053 POSTS
I need an engine size
and I will try to get you a picture
most likely at the front of the engine if you follow upper hose to engine and thermostat housing
Sunday, January 5th, 2020 AT 1:26 PM (Merged)
LESLIEWY
  • 2001 DODGE INTREPID
  • 6 CYL
  • FWD
  • 84,000 MILES
WHERE IS THE THERMOSTAT LOCATED ON MY 2001 INTREPID? AND HOW DO YOU GET TO IT?
2CARPRO JACK
  • 11,533 POSTS
Where the lower hose attaches to the engine. You need to lift and support the car, remove the skid pan and you will be able to see it. Great design huh? If you can find a shop to do it at a reasonable price, I would do it
LESLIEWY
Thank You for the help.
KOKO2608
  • 6 CYL
  • 109,000 MILES
Where is the thermostat located in a 2001 dodge intrepid? How do I get to it?
BMRFIXIT
  • 19,053 POSTS
V6
engine SIZE?
In the middle front top of the engine
two bolts
make sure engine cool
drain down the coolant
remove the hose
remove the housing
make sure you bleed air out after you install the new thermostat
BMRFIXIT
  • 19,053 POSTS
OK
2.7L V6
drain coolant
remove alternator belt
raise the car
remove alternator and set aside
remove lower radiator and heater hose from thermostat housing
remove thermostat housing bolts
good luck
DANOXLEY40
  • 6 CYL
  • FWD
  • 127,000 MILES
Where is the thermostat located on the 2001 Intrepid? Is this something I can change myself easily?
  • 108,319 POSTS
Hi:
Follow the upper radiator hose back the the engine. It will end at the t-stat housing. The t-stat is in the housing and can be easily replaced by removing the housing. If you need help, let me know.
DANOXLEY40
Thank you for reply. I have found housing unit, how do I change thermostat. Do I remove hose, after loosenging 2 bolts? Any special instructions? Thanks.
  • 108,319 POSTS
Hi:
First drain the coolant from the radiator or you'll have a mess. Next, remove the housing and the t-stat will be under it. Before replacing the new one, pay special attention as to the direction the old one is sitting in. After removing everything, make sure to remove the old gasket from both the housing and the intake. Make sure the surfaces are clean and tight before replacing everything. Just reverse the sequence.
If you run into trouble or have other questions, let me know.
JOEYB5639
  • 2000 DODGE INTREPID
  • 4 CYL
  • FWD
  • 100,000 MILES
Thermostat location 2000 intrepid 2.7L
There you go its located on the left side of the engine-see below
https://www.2carpros.com/forum/automotive_pictures/12900_thermostat_27_1.jpg
THEJERM
  • 6 CYL
  • 89,000 MILES
I have had a slight leak in my cooling system coming from whatever this picture is of. I thought it was the thermostat housing, I bought a new thermostat, went to unbolt this and tried loosening the bleed valve. Well, when applying torque to this bleed valve, the cover popped off. There is no fasteners, so, do I just "JB Weld" it back in place or do I need to buy a replacement (and if so... what is "it" called?) And, since this doesn't house the thermostat... where do I find it?
https://www.2carpros.com/forum/automotive_pictures/392196_0804092007_1.jpg
The thermostat is located on the lower drivers side of the block below the alternator. Its a pain to get at
THEJERM
Rasmataz,
Thank you for directing me to the thermostat. Any chance you could tell me what it was that I broke (in the picture) or, if I can just use JB Weld (or some other form of epoxy) to stick that cover back on?
Thank you
