1998 Dodge Dakota truck won't start
CINDI ALDERINK
  • 1998 DODGE DAKOTA
Engine Mechanical problem
1998 Dodge Dakota V8 Four Wheel Drive Automatic
won't turn over at all.
tapped on the starter with hammer. Nothing.
tried jumping. Nothing.
i'm sorry but i'm so broke! Please help.
thank you :)
Monday, June 14th, 2010 AT 7:10 PM
  • 110,192 POSTS
Hi Cindi:
I'll do my best to help. I need you to check a couple things. First, do the other electrical items work? Next, have you checked the battery terminals to make sure they are clean and tight? Is the battery producing a minimum of 12 volts? Finally, I need you to get a helper. Have the helper turn the key to the start position while you (using a volt meter) check the smaller wire on the starter for power. In the start postition, the starter should receive a minimum of 12 volts to that wire.
Let me know what you find.
Wednesday, June 16th, 2010 AT 8:42 PM
