1992 Dodge Dakota wont start
CBESCH
  • 1992 DODGE DAKOTA
  • 6 CYL
  • 174,000 MILES
I was driving about 65 mph and all of a sudden heard a pop under the hood on the passanger side and the truck died. I have alraeady replaced the crank shaft sensor, distrubutor coil and rotor and still have no spark. What else could I look?
Thursday, July 16th, 2009 AT 6:51 PM
BMRFIXIT
  • 19,053 POSTS
What do you have for engine size?
Was the timing checked?
Check if rotor turning when engine cranking
Thursday, July 16th, 2009 AT 9:40 PM
BEEF99
  • 152 POSTS
It could be your timing chain, or ignition control module, they aer usually located under the distributor cap or connect to the distributo somewhere or somehow. Get a manual and find where this is located but check you timing chain first.
Saturday, July 18th, 2009 AT 10:47 AM
