2000 Dodge Caravan Master cylinder
DAVID FREEMAN
  • 2000 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 126,000 MILES
Why do I need to have the brakes bleed quite often especially the front right wheel. This has been ggoing on for some time and my mechanic cannot find the problem. He fixes it and a week later the pedal is down to the floor board. Please help. Thanks. He has changed three master cylinders in the process.
Tuesday, March 23rd, 2010 AT 12:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check for fluid leak anywhere on the brake system. Also check out the vacuum hoses at the booster. Has the booster itself been tested yet?
Tuesday, March 23rd, 2010 AT 12:22 PM
TOBY1437
  • 5 POSTS
If you are not showing any leak, like I did, the master cylinder is bad. I grabbed one at a junk yard for $10 and had it in, in 20 minutes. Make sure to grab the right one. ABS? Traction Control? The fittings are different sizes on the brake lines depending on these features. If you grab the wrong one you will need a descond trip, like I did!
Good Luck!
Tuesday, May 4th, 2010 AT 10:19 AM
Related General Content
