1999 Dodge Caravan
1999 DODGE CARAVAN
ADKINS83
  • 5 POSTS
I have a 99 dodoge caravan with about 120,000miles on it...While i was driving today it died on me and I haven't been able to get it started since...The check engine light did not come on at all....I am stumped....Any suggestions? :wink:
Apr 25, 2007 at 2:24 PM
BOOTDOG
  • CAR REPAIR CONTRIBUTOR
  • 665 POSTS
i need some more details. does it crank, or just click? it could be may causes so i need more info.
Apr 25, 2007 at 3:24 PM
ADKINS83
  • 5 POSTS
It cranks...
Apr 25, 2007 at 4:05 PM
BOOTDOG
  • 665 POSTS
first thing to check is the fuel pump. turn the key to the on position and see if you hear a high pitch whine for a few seconds. also tap on the fuel tank with a hammer while someone else cranks the engine over to see if it starts. if so replace the fuel pump. if not unplug the harness going to the pump to see if you have power, if so replace the pump. if not, let me know and we'll dig deeper.
Apr 25, 2007 at 5:39 PM
ADKINS83
  • 5 POSTS
I had my dad look at it and it seems to be blowing the engine fuse.....maybe a bad wire?
Apr 25, 2007 at 6:22 PM
BOOTDOG
  • 665 POSTS
yes it's very possible that the fuel pump relay/fuse could be bad. if not, try what i told you then we'll go further. anyway good luck.... :)
Apr 25, 2007 at 7:49 PM
ADKINS83
  • 5 POSTS
The 20 amp. fuse that is getting blown under the hood that says engine...what is the primary use or purpose? My husband would like to know...
sorry to be a pain in the rear, but we are really trying to save as much money that we don't have a possible!!!!
Thanks :D :D
Apr 25, 2007 at 8:05 PM
BOOTDOG
  • 665 POSTS
if it's blown, replace it. that could be a problem too. they're inexpensive.
Apr 26, 2007 at 4:34 AM
ADKINS83
  • 5 POSTS
Lol....I guess I should be more specific.....My husband bought two of them yesterday and replaced it....When he would turn the key it would blow...They checked the fuel pump and don't think that is the problem....Like I said....I have no Idea...lol
Apr 26, 2007 at 6:44 AM
BOOTDOG
  • 665 POSTS
ok, i'm trying to find other moderators here on this site that has a mitchell 1. having this info will help diagnose your problem better. give us a little time and one of us will get back to you. sorry for the delay.
Apr 26, 2007 at 8:19 PM
BOOTDOG
  • 665 POSTS
I need to know the engine size of the vehicle.also is it a LE or SE on neither.
Apr 27, 2007 at 5:09 PM
MHERTEL51
Hi, your problem is the same we are having with a 1998 Caravan, did anyone ever solve the probem? this is my daughters and she uses it for daycare purposes so any help that you may have been advised to do would be greatly appreciated,
Thanks so much
Sep 8, 2007 at 4:29 PM
