1998 Dodge Caravan
1998 DODGE CARAVAN
SUSPENCE36
Engine Mechanical problem
1998 Dodge Caravan 6 cyl Two Wheel Drive Automatic
how to change alternator
Oct 24, 2008 at 2:12 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Hi:
First disconnect the battery. After that, you will need to remove the alt belt. Next, you will need to disconnect the electrical supply and all wires from the alt itself. Finally, I believe there are three bolts on your vehicle that will need removed. Once they are off, the alt can be removed.
To replace the alt, just reverse the order.
If you have any problems, let me know.
Positive feedback and votes are appreciated.
Oct 27, 2008 at 10:57 PM
