1997 Dodge Caravan
1997 DODGE CARAVAN
FRANKLIN_T8394
Computer problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
My 97 grand caravan 3.8, will not start I've checked the coil driver circuit going to the coil pack, and cylinders 2 & 5 flash and 3 & 6 do also but 1 & 4 stay lit even when the crank sensor is unpluged and the ignition is off. The test light light goes off when the pcm is unpluged. Got any ideas?
Dec 9, 2009 at 5:44 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
Do you have spark on any of the cylinders ??
do you have fuel pressure
with key on do you have check engine light on ,does the light go out when cranking
check for codes
to suspect
if no fuel pressure suspect fuel pump
if no spark suspect crank sensor ,ASD relay ,PCM
always check fuses and relays 1st
and then check for codes and pending codes
check if crank sensor and cam sensor in SYNC
Dec 9, 2009 at 6:34 PM
