Need a diagram on how to replace a serpentine belt on the car listed above 20 engine.
Saturday, September 8th, 2018 AT 12:11 PM
CJ MEDEVAC
MECHANIC
Here is the serpentine belt routing diagrams to help you step by step with instructions in the diagrams below to show you how on your car. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Saturday, September 8th, 2018 AT 4:57 PM
BARBARA1963
MEMBER
2007 DODGE CALIBER
2.0L
4 CYL
2WD
AUTOMATIC
I had to replace the alternator plus put a new battery because the alternator drained it, the car don't have a diagram on the car to put the serpentine belt back on and I didn't pay attention when I took it off, please send me the diagram please
Friday, December 18th, 2020 AT 9:58 AM
(Merged)
CARADIODOC
MECHANIC
Here's the diagram for your serpentine belt. Its a good idea to draw it on a clean flat spot under the hood with a sharpie if the decal is missing. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
(Merged)
ROSSRIZZO
MEMBER
1 POST
2007 DODGE CALIBER
Engine Mechanical problem
2007 Dodge Caliber 4 cyl Front Wheel Drive Automatic
where can I get a routing diagram for the drive belt car has a/c
(Merged)
DOCFIXIT
MECHANIC
SPONSORED LINKS
(Merged)
2CP-ARCHIVES
MEMBER
2007 DODGE CALIBER
50,000 MILES
Can I replace clutch of ac compressor because it make a big noise and im check it and use another diagram of serpentine belt?
Friday, December 18th, 2020 AT 9:59 AM
(Merged)
HMAC300
MECHANIC
Here is the serpentine belt diagrams below with a guide that will help walk you through he steps of replacement.
(Merged)
SHORNUF
MEMBER
1 POST
2007 DODGE CALIBER
V8
FWD
MANUAL
60,000 MILES
I suspected the fan belt was going because of the noise, but when the mechanic ran a "diagnostic" on it they said it was the air compressor. Is there any relation between the two?
(Merged)
CH112063
MECHANIC
Yes there definitely is. I'm sure your mechanic would rather it had not been the a/c compressor belt. He is correct. I am sorry you have this trouble. He will fix it with as little cost as possible I'm sure. The a/c is driven by the same pulley and if it is just the front it may not be too expensive. OK
