Rear brakes
DAVID NEIHARDT
  • 2008 DODGE AVENGER
  • 6 CYL
  • 63,000 MILES
Brake job instructions please?
Saturday, January 1st, 2011 AT 4:46 PM
SEVAG P
  • 405 POSTS
follow the instruction below you can do the job by yourself.
check our guide below how to replace rear pads and discs
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
check the diagrams below procedure how to replace rear pads and discs, also how to test and inspect discs.
hope these helps ,
thank you.
Sunday, February 7th, 2021 AT 4:55 PM
JOJOFRIJAS
  • 4 CYL
  • 19,000 MILES
When I lightly press on the brakes, there is almost like a very high cluster noise almost like something is loose, but its very not squeeky, but it just doesn't sound right and I know that its not rust or anything minor cause the noise that my vehicle makes when I lightly press on the brakes is not a tone sound, it kind of sound like something when you have a flat tire and it continuosly makes that rugged noise. But please help me and give me some pointers or advice please.
Tuesday, February 9th, 2021 AT 10:24 AM (Merged)
  • 108,310 POSTS
Hi:
I would start by checking the brakes and making sure the calipers are tight. Also, I believe the car is still under warranty. Have you brought this problem to a dealer's attention?
