Firing order for spark plugs
WILD TIGER
  • 2002 MITSUBISHI MONTERO
Engine Performance problem 6 cyl Four Wheel Drive Automatic
we changed the spark plugs, howver, we need to know the firing order as nothing is working
Friday, September 25th, 2009 AT 7:12 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Yes this is an easy engine to mix up the firing order for the spark plugs on. Here are some diagrams that should help you get them back on correctly.
Cheers, Ken
Thursday, October 12th, 2017 AT 8:10 PM
DONNA35
  • 1999 MITSUBISHI MONTERO
  • 3.5L
  • V6
  • 4WD
  • 100,000 MILES
I am looking for the diagram for the firing order for my Mitsubishi Montero Sport 3.5L V6 4X4 DHOC, and cannot find one. Can you help me with this?
Thursday, October 12th, 2017 AT 8:10 PM (Merged)
  • 31,938 POSTS
See pic for firing order and cylinder location
JAMES F. ANDERSON
  • 6 CYL
  • 106,856 MILES
I need the fireing order for a 1999 mitsubishi montero 3.5 v6 can you please help
See below
LARRY001111111
  • 2001 MITSUBISHI MONTERO
Electrical problem 6 cyl Four Wheel Drive Automatic
need to know firing order and how it goes for cylinders does it start on the pansenger side and go 1 then to driver side for 2 then second one back on passenger side is 3 then second one back on driver side is 4 then third one back on passenger is 5 and third one back on driver side is 6
KEN L
  • 42,904 POSTS
If you are facing the engine the 1, 3, 5 cylinders are on your left and the 2, 4, 6 are on your right. Here are the firing order for your car.
Cheers, Ken
NETGROCERIES
  • 1997 MITSUBISHI MONTERO
  • 6 CYL
  • 100,000 MILES
Need the order of the cables for spark plug from 1 to 6 in my engine. Thank for your help
Thursday, December 3rd, 2020 AT 8:47 AM (Merged)
Firing Order Specification . Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/12900_forder_1.jpg
