Battery light on
ZEMORZEMOR
  • 2006 CHRYSLER PT CRUISER
  • 2.4L
  • 4 CYL
  • FWD
  • 85,000 MILES
The battery light comes on and off.
when it comes on I turn off the engine and restart the car it comes off.
i think it comes on when the car sit for few hours a start the engine.
i checked the battery it hold charge and the alternator under load it seems good
what could be the problem
Sunday, February 2nd, 2014 AT 9:19 AM
SATURNTECH9
  • 30,869 POSTS
With the car at idle and the battery light on tell me what the voltage is at the battery?Sounds like a alternator going bad. Some die slow and some go suddenly.
Sunday, February 2nd, 2014 AT 11:13 AM
ZEMORZEMOR
  • 486 POSTS
The voltage when the car at idle and the battery light is on is 14.7 volt. The guy at oreilly is used to be a mecanic he checked the alternator and the battery. He told me the alternator is good he tested it under load headlight on and I gave him the battery he put it in the charger for 10 minutes he said the battery is holding the charge
Monday, February 3rd, 2014 AT 7:04 PM
JULIAHARM
  • 4 CYL
  • 41,000 MILES
about two days ago, my battery light went on when I was on an incline. I went to my mechanic who tested the battery and said it was charged. We turned the car on and off a few times and nothing. Then the battery light went on again later that night. I rinsed off some of the corrosion on the battery with water and it was fine for a day. Then, when I was going up a hill yesterday, the battery light went on again and has stayed on since - the cable connecting to the battery seems firm and only one of the cable attachments to the battery has corrosion - what should I do?
Monday, May 4th, 2020 AT 2:08 PM (Merged)
If the battery is in good condition with clean and tight posts/cables-have the alternator load tested might not be putting out or the battery is not taking the charge.
ZEMORZEMOR
  • 486 POSTS
  • 2.4L
  • 4 CYL
  • FWD
  • 93,000 MILES
The battery light is on. Today I replaced the battery and the battery light still on.
There is a DTC code p063a generator voltage sense circuit. The alternator is generating 14.5 volt when the car is running and under load
thank you
HOMER1967
  • 875 POSTS
This is a very common issue on that particular vehicle. There is a T.S.B. (Technical service bulletin) pertaining to that exact issue. The t.S.B. Number is 18-007-07. It requires updating and/or reflashing the pcm. Call you local dealer and ask them about the t.S.B. Number.
ZEMORZEMOR
  • 486 POSTS
  • 4 CYL
  • FWD
  • 86,000 MILES
I have a DTC code P063A.
Battery and alternator are good.
I hook up a voltmeter to the battery car and drove it the battery light came in when voltage was 14.3 volt
JDL
  • 16,098 POSTS
I saw a service bulletin related to the p063A code as well as other code. It was listed under driveability improvements. You reflash/reprogram the computer. You may need to take it to dealership? The ref number for the bulletin is 18-007-07.
PAM BURTON
  • 6 POSTS
  • 4 CYL
  • FWD
  • 47,300 MILES
I have had the battery and alternator checked they are ok what should I try next
Monday, May 4th, 2020 AT 2:09 PM (Merged)
  • 108,355 POSTS
Hi:
If the alt light is coming on from time to time, I say the alt is the problem. When it was checked, was the light on?
PAM BURTON
  • 6 POSTS
  • 108,355 POSTS
You need to have it checked when the light is on. My guess is that it's going bad.
PAM BURTON
  • 6 POSTS
Thank you it was a bad alternator
PAM BURTON
  • 6 POSTS
  • 4 CYL
  • FWD
  • 43,700 MILES
I have had the battery and alternator/genorator checked and everything checked out ok so where to I go from here?
  • 108,355 POSTS
Chances are the alt is on its way out. However, when you have it checked, it is working fine. I would think it will progressively get worse to a point that they will be able to identify the problem.
  • 108,355 POSTS
Pam, if you have other questions let us know, and I would like to kow how you make out with this problem.
PAM BURTON
  • 6 POSTS
OK Joe I will keep you posted
ZEMORZEMOR
  • 486 POSTS
  • 2.4L
  • 4 CYL
  • FWD
  • 85,000 MILES
I m looking for electrical diagram for the battery light.I want to check the circuit if it shorted
Thank you
MLDANIELS2000
  • 227 POSTS
Let me ask what kind of issue you are having. Maybe we can help you with it.
ZEMORZEMOR
  • 486 POSTS
The battery light comes on and after I turn off the engine and restart it it is not on anymore it does that every day so I think my be there is a short in the circuit
