Starter replacement
KEVIN ALLYN
  • 2005 CHRYSLER PT CRUISER
  • 2.4L
  • 4 CYL
  • TURBO
Will a starter out of a non turbo model work on my turbo model. I installed it and it sounds like it's just spinning I don't think it's kicking it out. Please help thank you
Thursday, May 21st, 2015 AT 9:19 AM
CARADIODOC
  • 33,755 POSTS
It sounds like you have a defective starter are have it installed incorrectly here is a guide to help with diagrams below to show you how on your car. Make sure you have a high quality rebuild for the starter like AC Delco.
https://www.amazon.com/gp/product/B014MW1UQO/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B014MW1UQO&linkId=fc39f22d083b3b380066c61c552674a7
Thursday, May 21st, 2015 AT 4:39 PM
JDBEAULOYE
Thank you for this post I had this problem and had to get an Delco starter the cheap one are no fun!
Thursday, October 24th, 2019 AT 5:54 PM
MOOKIE3604
  • 4 CYL
  • FWD
  • 86,000 MILES
How to remove starter, radiator fan blocking access.
Thursday, October 24th, 2019 AT 5:54 PM (Merged)
  • 108,328 POSTS
Are you trying to remove it from under the car or the top? You should be able to get it from under the car, but if you can't, you will need to remove the cooling fan / shroud assembly.
