EGR valve replacement
USMALE
  • 2002 CHRYSLER PT CRUISER
  • 120,000 MILES
How do I change the egr valve?
Saturday, June 22nd, 2013 AT 10:47 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,085 POSTS
You must start with the engine cold because it is by the intake manifold and you don't want to burn yourself. Here is a video on how to test the valve once you have it off. This EGR on this car is electronic.
https://youtu.be/DqUCbbKdWf4
Here are diagrams that will help you remove the valve on your car
Check out the diagrams (Below)
Cheers, Ken
Sunday, December 24th, 2017 AT 1:49 PM
JCMARTIN3
  • 4 CYL
  • FWD
  • MANUAL
  • 240,200 MILES
Engine Mechanical problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Manual 240200 miles
Engine light is on, computer diagnosis indicates EGR Flow Insufficient. Looking for detailed instructions on how to remove and clean/replace EGR valve and hose.
Sunday, December 24th, 2017 AT 1:50 PM (Merged)
REMOVAL
If the EGR system operates incorrectly, replace the entire EGR valve and transducer together. The EGR valve and electrical transducer are calibrated together.
Remove the air cleaner lid, disconnect the inlet air temperature sensor and makeup air hose.
Remove the negative battery cable.
Fig.5 EGR Tube At Intake Manifold
https://www.2carpros.com/forum/automotive_pictures/12900_egr1_4.jpg
Loosen the bolts at the intake manifold
Remove EGR tube bolts at EGR Valve.
Fig.6 EGR Transducer Bracket
https://www.2carpros.com/forum/automotive_pictures/12900_egr2_3.jpg
Fig.7 EGR Transducer Bracket
https://www.2carpros.com/forum/automotive_pictures/12900_egr3_2.jpg
Unclip EGR transducer bracket, and remove from bracket.
Fig.8 Vacuum Hose
https://www.2carpros.com/forum/automotive_pictures/12900_egr4_1.jpg
Disconnect the vacuum supply hose to EGR transducer solenoid.
Fig.9 Electrical Connector
https://www.2carpros.com/forum/automotive_pictures/12900_egr5_1.jpg
Unlock the connector then disconnect the electrical connector from solenoid.
Remove the 2 bolt at EGR valve to cylinder head. Remove EGR valve and transducer.
Clean gasket surfaces. Discard old gaskets. If necessary, clean EGR passages.
INSTALLATION
Connect vacuum supply tube to solenoid.
Attach electrical connector to solenoid.
Install EGR transducer into the bracket and snap closed.
Loosely install EGR valve with new gaskets.
Finger tighten EGR tube fasteners.
Tighten EGR valve mounting screws to 22 N.m (195 in. lbs.) torque.
Tighten EGR tube fasteners to 11 N.m (97 in. lbs.) torque.
NOTE: Make sure that the hoses are routed away from the hot EGR tube and Valve and clipped.
Install the negative battery cable.
Install the air cleaner lid, connect the inlet air temperature sensor and makeup air hose.
SRPMO
  • 2001 CHRYSLER PT CRUISER
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Manual 133k miles
Engine in my 2001 PTCruiser locked up. I bought low mile used engine without realizing that my car had EGR valve and used engine DOES NOT have EGR value. Can I somehow modify things to use this new engine or am I SOL?
For example, the head on my old engine likely is OK. Can I use old head on new lower unit?
Or can I use new engine if I replace computer? (I assume original computer would throw a code if engine did not have EGR)
You help greatly appreciated!
Hi SRPMO, Welcome to 2carpros and TY for the donation.
For example, the head on my old engine likely is OK. Can I use old head on new lower unit? I will go with this direction. Computer/Reflashing is much more than a headgasket
