1982 Chrysler Le Baron
1982 CHRYSLER LE BARON
SEBASTIAN LOPEZ
1982 Chrysler Le Baron 4 cyl Front Wheel Drive Automatic
Hello, Im looking for some parts and i can't find them. Ive got the list in spanish and a tranlasted to english version. Here are both: (im not pretty sure of this translation and may be thats the reason why i cant find them)
4xRodamientos Traseros: 2xREAR INNER BEARINGS, 2xREAR OUTER BEARING CONES
4xRetenes Traseros: 4xBRAKE DRUM RETAINING NUT?
4xBujes Templetes Traseros: (i dont know its translation)
2x Rodamientos delanteros: 2x FRONT BEARINGS
2x Bocines Delanteros Completos: 2x FRONT HUBS, RETAINER, GASKET AND WASHER
2x Tijeras: 2x CONTROL ARMS?
4x Bujes Tijeras: 4x CONTROL ARM BUSHS?
2x Rotulas: 2x BALL JOINTS
4x Soportes Motor: 4x ENGINE MOUNTS
1x Terminal de Direccion: 1x TIE ROD END
2x Brazos Axiales:?
1x Empaquetadura Carburador: 1x CARBURETOR GASKET
2x Calliper Frenos: BRAKE CALLIPER
Filtros y Empaques Caja de Cambios: AUTHOMATIC TRANSMISSION FILTERS AND GASKETS
Filtro de Aire: AIR FILTER
Manguera de motor:?
Filtro de Aceite: OIL FILTER
Empaque del capó: HOOD GASKET
Empaque de la tapa del baul:?
Lona de Capota: CONVERTIBLE TOP
If anyone can help telling me where to find them or any other solution i'll really appreciate it.
Thanks
Oct 15, 2010 at 8:42 PM
