1987 Chrysler 5th Avenue alternator
ZINCMAN18
  • 1987 CHRYSLER 5TH AVENUE
Electrical problem
1987 Chrysler 5th Avenue V8 Two Wheel Drive Automatic
I have a 87 chrysler fifth avenue with an 88 alternator on it everything fits fine in place I just dont know how to hook up the wires. It has 2 green small wires and 1 small black wire. And close next to it it has a sortof large but small black wire do I connect that to the alternator as well. I just dont know were the wires go on the alternator please help
Do you
have the same problem?
Sunday, May 11th, 2008 AT 9:40 PM
  • EXPERT
Hi:
I checked wiring for you vehicle and an 88. Listen, there are different alts for that vehicle. The one you have may have a different output level than you need. If it does, it could damage different components. I recommend that you purchase the correct alt for your car, or have it confirmed that the one you have is correct.
NOTE: Just because it fits doesn't mean it is correct.
Thursday, October 16th, 2008 AT 8:16 AM
Recommended Guides
