Brakes problem
1997 Chevy Truck V8 Four Wheel Drive Automatic
my brakes are mushy and it sounds like they are sucking air when the peddle is held down
Sunday, October 10th, 2010 AT 12:30 PM
HMAC300
MECHANIC
This could be the vacuum booster leaking and/or the master cylinder is going bad. Have a pro look at this soon.
Monday, October 18th, 2010 AT 7:20 PM
CHERRY GARCIA
MEMBER
Check the vaccum line going to the booster if it is good then the booster is probably bad and that is why you hear the sucking sound you are loosing vaccum. This can also make your vehicle run badly.
